4G32 Valve Spring
Re: 4G32 Valve Spring
I don't have any idea if it has a color code. But I have here a couple of color codes for the valve springs, just wondering if these are still available. Planning to change my springs since they've been in there for more than 30yrs.
I also have here a data of the cam#1 and cam#6.
The blue I would say are 4G37 as they have larger diameter valves. I have a feeling 4G63 SOHC 8 valve, as per L300, have the same spring. I may have info on that......
Roger
Roger
You mean I can use the 4G63 valves (SOHC) on my 4G32?
No, the valves are too big, but I think the springs may be able to interchange........I'll need to look up some old manuals I have.
ooppss.. my bad, i meant the valve springs...
I have here the data of the 4G63 SOHC and DOHC springs, can't figure out which of the two is compatible or has the same diameter with the 4G32 springs.
RPW has a single upgraded valve spring package for teh 4G32 engines. We could probably find a double as well if I looked hard enough.
Racing Performance Works - Mitsubishi Performance Specialists - yes we still work on older cars
Check our facebook page for updates - https://www.facebook.com/pages/Racing-P ... 3894620525
I think the dual springs are a bit too much for my application since the engine is basically stock, a slight upgrade on the single would be great.
how much is a set of these springs?Mitsiman wrote:RPW has a single upgraded valve spring package for teh 4G32 engines. We could probably find a double as well if I looked hard enough.
to get the facts without applying the "Webfilter" that turns so much crap into fact, ring RPW!!
