No 2 32 60 63 29 early 70's non pollution chain drive
No 6 24 64 67 21 GSR Lancer (8 74 book and an earlier book) chain drive
we did have all the specs on here but they got deleted
Roger
where did you get this #2 cam from? pre '73 or post '73?Torana68 wrote:well I just checked some Mits books and :
we did have all the specs on here but they got deletedboth my Mits books spec the No 6 for the Lancer GSR engine, which book you got that says the GSR had a no 2 with no 6 specs?
Roger
Thats as I understand it, cept the 2 is also the 1.5 GS cam, I dont think there would be a No2 with two different specs, the jap books are right Id guess the Chrysler book is wrong , I cant see Mitsubishi having two different spec cams both marked 2. I can see the No 6 being in anything that has pollution control and instead of saying the no 6 is the same a a late GS/GSR cam you should be saying the late GS/GSR has a std pollution cam same as the one fitted to the std engine. Pollution cams are not preformance cams and I wouldnt consider .7mm more lift as an advantage, it wouldnt make any difference . People have been ditching pollution cams for years for a reason.77GDWAGON wrote:From the info i have
No. O cam 1.3/1.5 (i have one)
No. 1 1.4/1.6 early ( edit; another book shows 1.2 4G36)
No. 2 1.6 GS
No. 3 1.7 GTO
No. 4 Factory works cam for C1 option on GS motor
No. 5 Factory works cam for C2/3 option with factory works flat top pistons (46/74 77/43)
No. 6 1.4/1.6 pollution motor
No. 7 i got this from a jap import motor that had heaps of pollution control crap
These figures for Nos 1,2,3,and 6 are the same as I have. Thanks for the figures for #4 & #5.77GDWAGON wrote:Here are some specs to look over
Cam No. Long Dia of cam Valve timing
Intake Exhaust
0
1 36.363 36.412 20/48 51/17
2 36.519 36.571 24/64 67/21
3 32/60 63/29
4 36.519 36.571 46/74 77/43
5 36.777 36.829 46/74 77/43
6 36.517 36.569 24/64 67/21
This wont display as i wrote it so it may be hard to read
