4g63t rwd flywheel?
lilvr4
4g63t rwd flywheel?
Post by lilvr4 »
hay there can i use the flywheel and clutch of mr vr4 dohc 4g63t or will i need a sigma flywheel and clutch as my gearbox is a sigma 5 speed
lilvr4
Re: 4g63t rwd flywheel?
Post by lilvr4 »
what about clutch can i use vr4 one?
BOOTS
Post by BOOTS »
lilvr4 wrote:hay there can i was the flywheel and clutch of mr vr4 dohc 4g63t or will i need a sigma flywheel and clutch as my gearbox is a sigma 5 speed
you can use standard flywheel just have to use a clutch that fits the gearbox your using
lilvr4
Post by lilvr4 »
ok thankyou
turbosigma
Post by turbosigma »
But had to use a sigma ring gear on the 4g63 flywheel - sigma ring gear is a bit bigger.
lilvr4
Post by lilvr4 »
just thought id give the gearbox a go with vr4 flywheel nd clutch and boom they match up
C_Fernance
Post by C_Fernance »
Does the starter work OK?
lilvr4
Post by lilvr4 »
yip
