hI GUYS, JUST SOME AA GASKETS PART NUMBERS FOR A 4G32, THOUGHT THESE MIGHT COME IN HANDY FOR SOME OF US TACKLING REBUILDS.... IGNORE THE SUBMIT FIELD /// ITS JUST ME BEING LAZY WITH CUT AND PASTE THATS ALL....HOPE THIS SAVES ON TIME WASTING.
Item List Print these details Print TecTip
Description Item Name Qty Notes
Submit Submit Full Set FJ690 1
Submit Submit Valve Regrind Set CJ692 1
Submit Submit Head Set CJ692HS 1
Submit Submit Conversion Set EJ690 1
Submit Submit Head Gasket AJ690 1 AJ690: Head gasket width 115.00mm
Submit Submit Head Shim AJ690S08 1 AJ690S08 T=0.8mm. AJ690S15 T=1.5mm also available.
Submit Submit Oil Pan HC371 1
Submit Submit Rocker Cover JM023 1
Submit Submit Rocker Cover Washer KJ212/2 1 KJ212/2 (4 cyl) Engine set.
Submit Submit Manifold Inlet HA045 1
Submit Submit Manifold Exhaust HA039 1 HA039 Round ports
Submit Submit Manifold Exhaust HA041 1 HA041 Square ports
Submit Submit Extractor Manifold EM110 1 EM110 Round ports
Submit Submit Extractor Manifold EM24 1 EM24 Square ports
Submit Submit Exhaust Flange JE011 1
Submit Submit Valve Stem Seal Set HR272PS 1 HR272PS Engine set. Bulk pack KJ211/50PS.
Submit Submit Camshaft End Seal LV575 1 LV575 Engine set.
Submit Submit Crankshaft Seal Front NJ007 1 NJ007 44*65*11mm.
Submit Submit Crankshaft Seal Rear RMS002PS 1
Submit Submit Timing Cover JR649 1
Submit Submit Timing Cover Set TCS08 1
Submit Submit Water Pump KL342 1
Submit Submit Water Outlet LS377 1
4G32 GASKET PART NUMBERS
The 20 year wait is OVER ! The GA is MINE I TELL YA , ALL MINE , BWAHAHAHAHAHA!
