lockable fuel caps oem
gday, did mits produce lockable fuel caps from any year 79-88? im looking for an oem one from my van (been syphoned lately) here is mine
Re: lockable fuel caps oem
i dont think they did but i went to my local autobarn and the guy there gave me one that fit basically perfect
My wagon has one, and I got another one from ebay just as a backup
r they genuine mits/oem, Sigmaproject?
You'll find that none of these cars ever came with a locking fuel cap, only a filler door lock (which was rubbish anyway...) A locking cap is a good idea but make sure you keep the spare key somewhere you can find it
what about trayback l200's I wonder?
If you can't find a lockable filler maybe modify the tube that goes to the fuel tank a put a mesh grate on it so you can't stick a hose in there?
There's a tapered 'spring' that you can force into the neck of the fuel filler - this was one method that was used to try and prevent fuel from being siphoned. Trying to put a metal gauze screen in there would pose a couple of problems I'd think.Merv wrote:If you can't find a lockable filler maybe modify the tube that goes to the fuel tank a put a mesh grate on it so you can't stick a hose in there?
Was/is that a product that was/is purchas-able from a supercheap type place?
and I wonder would it be easy to remove by somone siphoning?
Gas conversion?? Never seen some one syphone LPG :p
...MervMerv wrote:Gas conversion?? Never seen some one syphone LPG :p
There's also another advantage to having a locking cap on your fuel tank - it will stop idiots from tampering with your fuel too (or small kids putting the garden hose in it, filling it with sand and gravel or anything else they can get their hands on...)
Well it just involves access to the tank an emptier tank & a female to female connection.Merv wrote:Gas conversion?? Never seen some one syphone LPG :p
The most expensive car I've ever bought was a 1984 Mitsubishi... in 2014.
Where do I get one of these gezer101 ?geezer101 wrote:There's a tapered 'spring' that you can force into the neck of the fuel filler - this was one method that was used to try and prevent fuel from being siphoned. Trying to put a metal gauze screen in there would pose a couple of problems I'd think.Merv wrote:If you can't find a lockable filler maybe modify the tube that goes to the fuel tank a put a mesh grate on it so you can't stick a hose in there?
http://www.ebay.com/sch/sis.html?_kw=GA ... THIEF+COLD Good place to start research
