![Google :google:](./images/smilies/google.gif)
Item List Print these details Print TecTip
Description Item Name Qty Notes
Submit Submit Full Set FJ690 1
Submit Submit Valve Regrind Set CJ692 1
Submit Submit Head Set CJ692HS 1
Submit Submit Conversion Set EJ690 1
Submit Submit Head Gasket AJ690 1 AJ690: Head gasket width 115.00mm
Submit Submit Head Shim AJ690S08 1 AJ690S08 T=0.8mm. AJ690S15 T=1.5mm also available.
Submit Submit Oil Pan HC371 1
Submit Submit Rocker Cover JM023 1
Submit Submit Rocker Cover Washer KJ212/2 1 KJ212/2 (4 cyl) Engine set.
Submit Submit Manifold Inlet HA045 1
Submit Submit Manifold Exhaust HA039 1 HA039 Round ports
Submit Submit Manifold Exhaust HA041 1 HA041 Square ports
Submit Submit Extractor Manifold EM110 1 EM110 Round ports
Submit Submit Extractor Manifold EM24 1 EM24 Square ports
Submit Submit Exhaust Flange JE011 1
Submit Submit Valve Stem Seal Set HR272PS 1 HR272PS Engine set. Bulk pack KJ211/50PS.
Submit Submit Camshaft End Seal LV575 1 LV575 Engine set.
Submit Submit Crankshaft Seal Front NJ007 1 NJ007 44*65*11mm.
Submit Submit Crankshaft Seal Rear RMS002PS 1
Submit Submit Timing Cover JR649 1
Submit Submit Timing Cover Set TCS08 1
Submit Submit Water Pump KL342 1
Submit Submit Water Outlet LS377 1
