Hi all,
Bought myself a 2 litre sigma motor (was an auto) and want to mount it up to my 4speed thats in my galant currently...
Pulled the flywheel and clutch off the 1.6 BUT, the galant is a 5 stud mount, and the sigma is a 6 stud..
Do i just need a flywheel off a 2 ltr motor? Will my clutch mount to that??
Thanks!
2Ltr sigma motor into GD HELP!
Re: 2Ltr sigma motor into GD HELP!
Apparently you use a 2l fly and clutch. But I could be wrong. And yes your 4 speed will bolt up to it
N/A ALL THE WAY
Ahhh so i cant use my clutch off my 1.6 (and 4 speed?)
Spewing.....
Now where do i find a flywheel and clutch haha
Also, will the flywheel and clutch off my 4g63T work? (id rather find out before pulling it all apart)
Spewing.....
id say be safe and try and find a 2lt flywheel and clutch, the 4G63 one will most likely be different again, but i might be wrong
not the easiest to find apparently haha...
The search continues!!!
A narrowblock g54 flywheel could work, the g63 flywheel would require milling the center hole to fit the pilot bearing. The swap is pretty straight forward though and yes get the 2L clutch kit. If you look at my '75 wagon build thread, I did this same swap already. Only the g52 was out of my 77 wagon which was also auto ;).
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
The only narrowblock 2.6 flywheels are from Magnas (FWD's are always Narrow block).RaptorReed wrote:A narrowblock g54 flywheel could work
Can anyone confirm a Magna 2.6 manual flywheel will fit a 2.0 motor?
Forgot you guys didn't get narrowblock manuals in RWD like we did.
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
