How To: Fit a VR4 4g63 engine
Postby C_Fernance » Thu Apr 28, 2011 4:30 pm
Fitting a VR4 engine into a Sigma or Galant is a much talked about upgrade. Whenever anyone asks about fitting a newer, more powerful engine into an older Mitsu the answer is generally "get a VR4 - it bolts straight in" Indeed it can bolt in, but there is quite a lot of work involved that doesn't seem immediately obvious.
Having recently put one in my GH Sigma that originally had a 2.0 litre I found out some of what is involved - and I took the easy way out buy getting an engine that had already been set up for RWD. I'll try and break it into sections and include (dodgy edo spec :$ ) pics where possible. This is by no means the only way to fit these engines, just how I have done it. I have the engine fitted in same spot as the original with no mods required to the firewall, etc.
The Engine
Make sure you are getting a VR4 engine, and not one out of an RVR or an Evo. The VR4 has a 6 bolt crank that matches the Sigma flywheel. The others do not. The main areas that will need modifying to fit it are the inlet plenum/throttle body, thermostat housing, CAS and the turbo/exhaust manifold.
Gearbox + Clutch
This is one part of the job that can actually be "bolt in". The bellhousing pattern matches up perfectly with the narrow Sigma pattern. This means that if you have a manual box off a 2.0 litre (and possibly 1.6's) then it will bolt straight onto the back of the engine. If you have the right engine with the 6 bolt crank then the Sigma 2.0 flywheel, pilot bearing, bearing spacer and so on will also bolt straight on. A heavy duty clutch will probably be required to handle the extra power - but if it fits a Sigma then it will fit the VR4 with the Sigma flywheel. The only part of this whole section that doesn't bolt up is the metal plate sandwiched between the engine and bellhousing. You will need to use a sigma one but the holes for the 2 small bolts that hold it to the block don't line up. You could modify it to suit but once the box is on it won't go anywhere anyway.
Starter Motor
I have kept the starter separate from the gearbox as it is one part that almost caught me out. I went to fit the VR4 starter only to find that it didn't want to tighten up flush against the bellhousing. The body was too big a diameter and was hitting the side of the block. The sigma starter is a smaller diameter so it fitted great, and still starts the engine with no problems.
Engine Mounts
This is one section that seem to confuse a lot of people. The engine I got came with a set of dodgy looking mounts that had been made to move the engine forwards about 50mm. This had been done to allow room behind the engine for the thermostat, but caused other issues with the steering and so on. The way i have fitted the engine this isn't necessary. I originally got a pair of Starion engine brackets (other RWD 4G63 brackets out of an L200 etc may also work) These will bolt straight onto the engine block, and straight onto the sigma rubber mounts. Only problem was one was bent. But this led to another finding. The bracket off the exhaust side of an Astron will fit great if you drill 1 extra hole. I could have trimmed it down and made it neater but I was in a hurry that afternoon.
Inlet manifold + Throttle Body
The problem with the maniold is pretty obvious. The throttle body is on the wrong end. Easiest fix is to block off the open end with a plate (this can be used later on to fit vacuum fittings, etc if you want.), then have someone weld a new flange onto the other end. The standard VR4 throttle body has a very restrictive looking elbow that bolts to the front of it. After a quick Google search I found out this is commonly swapped with the throttle body off a later 4g63 or TR Magna which is slightly bigger and has a more conventional style that will allow a 70mm hose to be clamped onto it. Picked one up off ebay for a couple of dollars and swapped it over, blanking off the pollution stuff on the bottom at the same time.
Exhaust Manifold/Turbo
I can't really go into much detail here as my engine has had the exhaust manifold cut and welded to convert it to a high mount manifold before I got it. With the standard setup the turbo will foul against the steering box. I have heard that the turbo can simply be rotated to get the clearance required though I'm not 100% sure on this. By making it a high mount setup you will have more room for the lower radiator hose (at least the way I have done it). For the oil feed line from the back of the head I have used a speedflow banjo fitting to give me as much clearance as possible from the firewall.
CAS
The Crank Angle Sensor is another area I can't really comment on. Mine has been removed and now runs a trigger wheel on the crank itself. The engine has to be run off an aftermarket computer to do this.
Thermostat Housing
I thought this would be an easy job when i found this JayRacing kit http://www.jayracing.com/index.php?main_page=product_info&cPath=13_94&products_id=28. It fits into the head where there was originally a welsh plug.
However after receiving it and attempting to fit it I realised that it doesn't clear the water pump pulley. The rear block off plate fitted fine though. In the end i had it modified so that it comes out of the head at a 30degree angle rather then straight, giving me just enough clearance from the pulley. You will however need to remove a decent amount off the old mount that sticks out the timing cover in order to do this.
In addition to this the top of the housing was rotated slightly so the outlet was 90degrees to the engine/radiator. It then fits up to the standard radiator using a cut down section from the original Sigma top hose. You will need to use a thermo fan as there is no where on the engine that you can really mount a mechanical fan.
Lower Radiator Hose
For the lower radiator hose the metal inlet pipe into the back of the water pump was bent 90 degrees under the exhaust manifold. A 90 degree section of hose (05-0434 off a landcruiser) then brings it up past the the alternator. It then joins into a 'S' bend section off hose which connects to the original radiator.
Alternator + Wiring
I used the VR4 alternator as it is already fitted to the engine, and it has a much higher output compared to the original. Only problem is it is on the other side of the engine bay, and has an extra wire. I started out by stripping back the harness from the battery, starter etc all the way back to where it goes into the firewall. For the main power from the alternator I ran an 8g cable from the alternator to the battery. The original was cut off where it joined the loom. The other original wire to the alternator (charge light) was then relocated down the other side of the engine bay to connect to the smaller diameter of the 2 wire that plug into the new alternator. The other wire that plugged into the new alternator (voltage sense?) was attached to the main power cable in the loom similar to the original main power from the old alternator.
Fuel System
Nothing special here, just your usual lift pump, surge tank and high pressure pump that you would find in any EFI conversion. Just make sure the pumps can flow enough to supply the engine with enough fuel.
Intercooler + Piping
For the intercooler i was looking at using either a 600x300 unit (would need a fair bit of modding) or a 450x300 (should fit a lot easier). In the end I ended up with one out of an Evo 7. This was the perfect width to fit great apart from the inlet and out lets, and looks like a factory radiator when painted black. I cut off the original pipes had some tight radius bends welded to the tanks. I had to enlarge the bumper bracket holes and modify the bonnet catch bracket but done carefully it all looks almost factory. I then used 2 1/2" alloy piping to the turbo and throttle body.
That's pretty much all the main issues covered I think. I haven't really gone into wiring as I have used an aftermarket computer. Depending on what computer you use things could be a lot different. I was able to do nearly the whole conversion myself in a carport - the only work i couldn't do myself was the aluminium welding and the exhuast manifold. Some welding was also required for the intercooler brackets and the bonnet catch bracket, but this would all depend on what intercooler you use.
If you have any questions feel free to ask, and if you have any suggestions on other ways to fit the engine then your input would be appreciated. This is still very much a work in progress so you will have to forgive the messy and dirty engine bay.
C_Fernance
Country: Australia (au)
Re: How To: Fit a VR4 4g63 engine
Postby ghuphill » Thu Apr 28, 2011 8:02 pm
good stuff mate,a few blokes contemplating this conversion would benefit, :thumpsup:
ghuphill
Postby Tj. » Thu Apr 28, 2011 8:43 pm
How did your water pump pulley foul on the Jayracing front water outlet? Mine went in with no dramas at all. I have used a starion water pump which did need to be modified a little bit so it clears the timing belt tensioner. I've also had a spacer made up to bring the pulley forward a little to line up with the crank pulley. Time will tell if this was a good idea or not.
Using a starion water pump allowed me to utilise a transfer pipe from an Express van (which is presumably the same as a starion, they're just hard to find parts for) which with a little modification that'll be detailed in my post soon, allows me to connect the heater! :thumpsup:
The 4 speed galant box (from a 1.6L 4G32) is the same narrow block pattern and bolts up fine.
I used a flywheel from an Express van that had a 6 bolt single cam engine. wish i'd known that a 2L sigma fly would fit, I have one of those engines gathering dust in the garage.
I sourced my engine from a Hyundai Sonata (what?... don't look at me like that) and the sandwich plate between the block and gearbox fit fine. Evo's could be different mind you.
Good thread, I was thinking about doing his myself once mine's done. I went N/A in a galant so I've probably got other methods and ideas. I too figured it out as I went so there's bound to be different ideas to be brought together in one source.
Great work! :thumpsup:
viewtopic.php?f=46&t=485
Tj.
Postby woops » Thu Apr 28, 2011 9:51 pm
Great write-up there. The only things I would probably add would be that if using the front thermostat relocation then water pathways in the block are recommended to be modified with enlargements in the rear and restrictions in the front to help to promote water flow to the back of the head. This is to prevent hot spots developing at the rear of the head due to the thermostat being relocated. Although there are many people who have used the front thermostat relocation and have reported no problems.
There is also the option of getting a rear mounted thermostat which helps to tidy up the engine bay but you need to use a remote thermostat which can be gotten from the early nineties carby corolla. The starion guys use these pretty frequently as another option and they make batches of them for group buys on the starion forum every now and then.
Oh also I can confirm in the sigma's you can run the CAS if you massage a bulge on the firewall to fit it. The galants are a bit more tighter on the space situation so the firewall either needs to be cut or massaged a bit more and the heater piping needs to be modified. Can't confirm about the Lancer but i suspect they would be pretty similar in that respect as the galants. The VR4 computer and wiring can also be used and I think from memory there was only a couple of wires which need to be found on the ecu to splice it in.
woops
Postby 13bsigma » Thu Apr 28, 2011 10:23 pm
GREAT work Chris! awesome read and very helpfull.. one question.. you could also just use a starion bottom end with a VR4 head couldn't you?? is this more work than your way??
13bsigma
Postby C_Fernance » Thu Apr 28, 2011 10:27 pm
Not sure why your out let fits but mine didn't. I'm not the only one thats had that problem though. The actual outlet clears the pulley, but there wasn't enough room to be able to bolt the thermostat housing on. A pic will probably show it better.
13bsigma wrote:GREAT work Chris! awesome read and very helpfull.. one question.. you could also just use a starion bottom end with a VR4 head couldn't you?? is this more work than your way??
Starion bottom end is definitely possible, and i'm actually thinking of changing over to one if i get hassled at rego as it wouldn't need a cat converter, etc. The biggest difference is they are the wide block so you would need to use a Starion box or a 2.6 manual box. From reading up about it on the Austarion site you have to use the correct crank as well. Only reason i didn't go with one straight up is that I would have to build the bottom end to suit where as the VR4 engine I could drop straight in as it was.
C_Fernance
Postby Tj. » Fri Apr 29, 2011 9:02 am
I can see why now, my pulley is different. It's almost flat where as yours is offset towards the head.
Tj.
Postby dwlee » Fri Apr 29, 2011 5:38 pm
I also had a similar issue with the Jayracing front exit and I am using a rwd waterpump. It was an easy fix with welder.
dwlee
Country: New Zealand (nz)
Postby 81GL » Fri Apr 29, 2011 9:14 pm
Great write up Chris.
Made it a sticky for future reference.
1976 Galant: "Totally stock officer"
"I was drag racing. I'm a drag racer.", "You were drag racing?", "Mmm.", "In a Prius?", "I don't win a lot."
81GL
Postby JackBates » Sat Dec 01, 2012 5:11 pm
Hey man I have bolted in a 1990 sohc EFI 4g63 galant engine, but am struggling with the wiring did you do the wiring yourself?
JackBates
Postby BIGDAN » Mon May 19, 2014 7:26 pm
For the people that have done this ...... the turbo ... is around the wrong way what did people do to fix this and properly ?
BIGDAN
Postby C_Fernance » Mon May 19, 2014 10:28 pm
The manifold I used on the conversion in the pics had been cut and welded to turn it into a 'high-mount' setup.
Another option is an adaptor plate that bolts to the head, and has a new bolt pattern/studs that allows the manifold to be bolted on upside down.
The November 2000 issue of Hot 4's has a how-to conversion story on putting a VR4 engine into a GH Scorp. In this they kept the low mount turbo. It states "For the turbo to clear the steering box, the compressor housing is rotated 180 degrees to give clearance of around 10mm." and "with a bent pipe directing the charge air forward".
C_Fernance
Postby JBSTAZ » Tue May 20, 2014 1:27 pm
I have a custom steam pipe T3 flanged manifold 4 sale .It i9s a split pulse design that you can nuse a single entry turbo as well and it also has a 40mm Vband ext gate connection IT IS IN PERFECT ORDER AND THE MATING FACES HAVE BEEN MACHINED FOR A PERFECT FIT TO THE TURBO AND HEAD $500.00 + post can send pics on phone if needed
JBSTAZ
Who is online
