hey guys
ive added a 36-1 triggerwheel and vr sensor to the front of my crank to fire an EDIS (electronic distributerless ignition system)
my question is if i were to get an aftermarket ecu, could i remove the dizzy completely or would it still be needed for the crank angle sensor? even though my 36-1 wheel and vr sensor IS a crank angle sensor?
cheers,
rob
crank angle sensor
crank angle sensor
- amgis_obrut
Re: crank angle sensor
I think you could drop the dizzy and use the commo sensor if your ecu is configured to run that way
give John @ microtech a call
or
Adam @ JEM 02 961860001
or
^^ Correct. Effectively all a distributor does is send spark at the cranks direction. By fitting the trigger wheel and sensor you will be telling the ECU when to fire the coil packs so the distributor is just plugging a hole. Give the guys mentioned above a call to find out which ECU is suitable for your application. I would think you can even run the VR coil packs and use bits of the VR loom
