front crossmember from vn dunnydore
bruggz351
Post by bruggz351 »
Has anyone measured up a Commodore "K" frame? Would that graft into a Siggy? Would give you rack and pinion steer too.
Billsy
Re: front crossmember from vn dunnydore
Post by Billsy »
dunno about a VN, but i ha look under my VX and the commo is Drastically wider than the siggy, so its highly unlikely its doable without MAJOR mods to either or both.
webby
Post by webby »
If I remember right, the VT/VX is a fair bit wider than the VN-VS platform.
Had a look under my VC a while back and it looks closeish, and I know for a fact that a VN crossmember bolts into a VB-VL, so it might work. Dunno. Would probably need mods like Billsy said.
bruggz351
Post by bruggz351 »
Hmmm. Think I must investigate. 8o|
