Head torque settings
slugma
Post by slugma »
Hey guys, i should be getting a new head at the end of the week.
My brother in law will be helping me fit it, (more to the point, ill be helping him!!)
He has said ill need to get the head torque sequence and how much to torque them.
If anyone here know this info, or where i can find it, that would be awesome!!
Thanks again guys.
Cheers, Matt.
MY05 GT Liberty
83 GJ Sigma
dvsfin
Re: Head torque settings
Post by dvsfin »
it will have that information on the head gasket package
slugma
Post by slugma »
Thanks buddy! Let's hope its still in its packaging!
MY05 GT Liberty
83 GJ Sigma
If it doesn't, or just to be safe hit 84GKSIG with a PM, he has just about every Sigma owners manual, he will be able to give you the settings.
http://sigma-galant.com/memberlist.php? ... file&u=149
slugma
Post by slugma »
Thank you! I'll be sure to contact him if I need it!
MY05 GT Liberty
83 GJ Sigma
tubby
Post by tubby »
astron 1 manual says: cylinder head bolts 89-98 nm, cylinder head to timing cover bolts 15-21 nm
astron 2 manual says: cylinder head bolts 110 nm, cylinder head to timing cover bolts 12 nm
cylinder head bolt tightening sequence
8 6 1 3 9
10 4 2 5 7
(if that makes sense)
amehel0
Post by amehel0 »
By cylinder to timing head bolts they are the ones that are the closest to the fan side of the engine and need to be tightened to a lower torque then the actual head bolts. Make sure that you untighten them in this sequence:
1 4 6 11 9 3
1 2 8 10 7 5
The number one is the timing chain cover bolts. Also only break the bolts and then go back through and undo them. Then re tighten them in reverse of that sequence from the centre out. do it in 3 stages of torque i use 50,80 and then 108-113 Nm This is one of the most important fastenings in the engine so take your time and make sure you have used the correct torque. Also make sure you have a torque wrench with a high enough torque range. if your going to buy one get a large one around 200Nm as if you ever do a clutch replacement your going to need a lot of torque to tighten the flywheel.
amehel0
Post by amehel0 »
Forgot to add the info i gave is for an Astron II and its what mitsubishi has in there manual.
