Hi all. Can anyone measure the carb bolt spacing on their spare 4g54 manifold?
Many thanks!
4g54 carb bolt spacing
Re: 4g54 carb bolt spacing
The mounting studs are (measured from the centre of the holes) 45mm across from centre to centre - 80mm lengthways from centre to centre. The studs are an M8 size. These are the dimensions for all Mikuni / Solex type carburettors.
Thanks so much
