Is my dizzy a tooth out? (pic)
Re: Is my dizzy a tooth out? (pic)
I would start reading up on your Wolf ECU. It will all come down to what IT requires, not what you have.
wah11
Post by wah11 »
The ECU reads it needs a crank angle sensor,
My mate just pointed something out.
I have a 92 NH pajero with 2.6 astron 2 that has a dizzy with no points, and the old style standard coil.
The magna with EFI has a newer style compact coil.
If i change the dizzy to the magna dizzy on my conversion, do i need to change the coil to the newer style or can i just use my standard oil coil set up.
