Revving Problem!
moparfanatic
Revving Problem!
Post by moparfanatic »
Every time I go to start the car(most times), the engine starts revving until the engine warms up! My car is a Galant GSR HH 1992
Alan
Re: Revving Problem!
Post by Alan »
Are the revs going up and down continuously?
If so, you may have a vacuum leak.
Check the intake manifold gasket, the plenum gasket, and the throttle body gasket. Also inspect the vacuum hoses.
If you have a butane/lpg torch, you can carefully spray some gas around the manifold while the engine is running to test for leaks. If the revs increase, that indicates a leaking gasket. Be very careful, as you could easily burn yourself should the gas suddenly ignite.
Cheers,
Alan.
moparfanatic
Yes! the revvs go up and down continuously!I'll try that gas trick! Thanks!
