MX6 injection manifold on 4g54?
astron_on_boost
Post by astron_on_boost »
Hello peoples,
i stumbled across this youtube footage
http://www.youtube.com/watch?v=6uiCZ1WvgCc
where it shows an MX6 intake manifold on a 2.6 g54B. I would think the manifold is off a fwd mx6 but didnt think they would fit? If these can fit, they make a refreshing change to the magna manifold & may not need the throttle body modification. Has anyone got any info on this?
LEE
Re: MX6 injection manifold on 4g54?
Post by LEE »
why use MX6 when you can use mazda bravo ! thats if it will fit , I new the blocks were close , but the heads I thought were different- somebody else out there?
Cottees
Post by Cottees »
Not sure if it was the same car or not, but I remember something about the Mazda manifold being cut off at the mounting plate (or what ever it was called), bent, and welded to one from an Astron.
LEE wrote:why use MX6 when you can use mazda bravo ! thats if it will fit , I new the blocks were close , but the heads I thought were different- somebody else out there?
The Bravo, B2600, Courier, Raider use a 12 valve head, so I would think it is different to the Astron head. I wonder if it is the same as the Jet valve head??
woops
Post by woops »
I'd dare say it'd be cheaper and easier to just use a magna manifold which is already made to suit than try to mod something else to fit. I'd say the reason they went to the effort to use a mx6 manifold is due to the fact it's difficult to get affordable multipoint manifolds over there to suit their starions. We have it easy getting the manifolds over here.
Paddles
Post by Paddles »
very interesting indeed. does anyone have a manifold sitting around, would be interesting to compare pics of both types of manifolds.
Cottees
Post by Cottees »
The 12v engine in the Mazdas is the G6 engine that replaced the 4G54. I think they share the same displacement though. I have had a look at the 4G54 vs G6 heads, and they are different enough to not be compatible.
4G54
G6
amgis_obrut
Post by amgis_obrut »
I played around with one of these heads some years ago and it was pretty close to going on
From memory the headbolts holes and bore spacing was the same but i think there were some oil galleries that needed welding up and external lines fitted
I think this is a very doable swap
Cottees
Post by Cottees »
Another problem would be that the exhaust and intake are on opposite sides.
I think another problem is that my Raider is totally gutless and drinks like there is no tomorrow. I would be happy to bin the G6 and chuck a efi converted 54 in there
Paddles
Post by Paddles »
i was more wondering about the intake manifolds bolt pattern and if the intake holes line up?
Cottees
Post by Cottees »
The top gasket here is the part that bolts to the G6 head
view of the intake side of the G6 head
view of the intake
found the pics here: http://www.mx6.com/forums/1g-mx6-forced ... d-one.html
MrBishi
Post by MrBishi »
It doesn't bolt up.
The only reason guys in the US bother modding other stuff to fit is because Magna intakes are not freely available there.
Australia was the only place that got a factory multi point manifold that BOLTS ON so why not take advantage of that fact?
Either gen magna intake can be had for peanuts - why reinvent the wheel?
LEE
Post by LEE »
^^^^ so true
Sean
Post by Sean »
May be a bit of confusion here regarding Mazda/Ford stuff and Astron motors.
87-89 Mazda licensed (not sure if they built or bought) the 4G54 from Mitsubishi to use in their B2600 / Bravo and in Australia the Ford Courier which they refered to as the G54.
From '89 on they switched over to their own 2.6L 4cyl motor called the G6.
So gear from a Mazda from 87-89 with the Mitsubishi engine will work on your Astron.
This then leads to the possibility of gearbox swaps as the Mazda's used their own detachable bellhousing to their own box behind the Mitsubishi motors. The bolts between the Bravo gearbox and bellhousing and the RX7 gearboxes and bellhousings are the same, meaning that an RX7 box can be bolted up to an Astron motor using the B2600/Bravo/Courier bellhousing.
The RX7 box then has the same spline as our Jap boxes and you can use your normal sigma/scorpion clutch with it.
I know nothing however about these passenger car manifolds, but I'll echo the comments that the Yanks would be adapting what they can get their hands on easily - and that isn't fuel injected 4G54 gear like we have.
Sean
Paddles
Post by Paddles »
i was not trying to re create the wheel, just checking things out. MX6 injection dont;t work basically without major mods, we have a ready supply of magna parts.
interesting about the mazda bravo bell housings and rx boxes. i assume the bravos came out in wide block??
