4G54 Timing Chain installation
Postby Emerald8779 » Fri Jan 15, 2016 11:42 pm
I just need to know how the timing is setup, adjusting cams, distributor, etc.. TDC, just new to timing. Engine: 4G54, without silent shaft.
Emerald8779
Country: Australia (au)
Re: 4G54 Timing Chain installation
Postby Scorpma82 » Sat Jan 16, 2016 3:35 pm
Best to use the search button in top right corner of screen.......plenty of info on it
Postby A112H » Sat Jan 16, 2016 9:09 pm
Postby Emerald8779 » Sun Jan 17, 2016 12:34 am
The picture is helpful, but on the gears i have are no alignment marks, so im not sure where to set the cam to
Emerald8779
Postby A112H » Sun Jan 17, 2016 7:08 am
On the very outer rim of the cam gear just before the teeth the should be a small dimple, maybe 2mm across. This needs to be at the top when the crank is at TDC.
I have a few cam wheels around, let me go grab a picture
Postby A112H » Sun Jan 17, 2016 7:16 am
Postby Emerald8779 » Sun Jan 17, 2016 11:07 pm
Okay awesome, that clears that all up, what is the oil capacity for a 4g54 Engine? Out of a 1985 Pajero.
Emerald8779
Postby Scorpma82 » Mon Jan 18, 2016 11:44 am
4.8L from memory
Postby Emerald8779 » Sat Jan 23, 2016 3:30 pm
I did what you said about the dimple and, put that at 12 oclock and the crank at tdc and it appears to be backfiring out of the carby
Emerald8779
Postby Emerald8779 » Sat Jan 23, 2016 3:32 pm
Did i mess up or is my distributor firing at the wrong times and igniting the fuel while that pistons vavles are kpened to exhaust?
Emerald8779
Postby Emerald8779 » Sat Jan 23, 2016 3:34 pm
Sorry i meant opening to fuel vavle
Emerald8779
Postby A112H » Sat Jan 23, 2016 4:32 pm
Sounds like the dizzy is 180 degrees out
Postby Sigmaproject » Sat Jan 23, 2016 4:52 pm
It will backfire and carry on even if it is only one tooth out on the dizzy.
Sigmaproject
Postby Emerald8779 » Sat Jan 23, 2016 5:29 pm
How can i test that?
Emerald8779
Postby Emerald8779 » Sat Jan 23, 2016 7:04 pm
On top dead center on the crank markings, its on either fuel stroke or exhaust stroke, not compression stroke, does that mean i have wrong timing chain setup?
Emerald8779
Postby Sigmaproject » Sat Jan 23, 2016 8:28 pm
You want TDC on the compression stroke. This is when the pointer on the front pulley points to TDC..and both valves for #1 cylinder are closed. TDC on the compression stroke the valves will be partially open. Once you have TDC compression stroke you need to find the marking on the dizzy for #1 cylinder. If you line up the dizzy so that it is at about the right angle to install in the head..just a bit right of centre near the cap mating surface you will find a marking that indicates the #1 spark plug lead location. To get the rotor to point to # 1 (around the 12'oclock position) after the dizzy is fully seated in the head ..you need to install it at the 2 oclock position. The gear on the dizzy will rotate it back to the 12 oclock position as you push it home. Install the rotor..replace the cap and If you firing order is correct..and you have fuel.. it should start.
Sigmaproject
Postby Emerald8779 » Sun Jan 24, 2016 6:16 pm
Okay i tinkered about, it starts, but there seems to be squealing from the carby
Emerald8779
Postby leoca64 » Wed Dec 28, 2016 9:04 am
...BTW - How often should the timing chain be done on the 4G54 ?
leoca64
Postby Scorpma82 » Wed Dec 28, 2016 11:25 am
technically they never need doing
but for assurance......id check the tensioner every 12months...and replace the chain on every rebuild
Return to Technical Questions
Who is online
Users browsing this forum: No registered users and 2 guests
