4G54 Timing Chain installation
Posted: Fri Jan 15, 2016 11:42 pm
by Emerald8779
I just need to know how the timing is setup, adjusting cams, distributor, etc.. TDC, just new to timing. Engine: 4G54, without silent shaft.
Re: 4G54 Timing Chain installation
Posted: Sat Jan 16, 2016 3:35 pm
by Scorpma82
Best to use the search button in top right corner of screen.......plenty of info on it
Posted: Sat Jan 16, 2016 9:09 pm
Posted: Sun Jan 17, 2016 12:34 am
by Emerald8779
The picture is helpful, but on the gears i have are no alignment marks, so im not sure where to set the cam to
Posted: Sun Jan 17, 2016 7:08 am
On the very outer rim of the cam gear just before the teeth the should be a small dimple, maybe 2mm across. This needs to be at the top when the crank is at TDC.
I have a few cam wheels around, let me go grab a picture
Posted: Sun Jan 17, 2016 7:16 am
Posted: Sun Jan 17, 2016 11:07 pm
by Emerald8779
Okay awesome, that clears that all up, what is the oil capacity for a 4g54 Engine? Out of a 1985 Pajero.
Posted: Mon Jan 18, 2016 11:44 am
by Scorpma82
4.8L from memory
Posted: Sat Jan 23, 2016 3:30 pm
by Emerald8779
I did what you said about the dimple and, put that at 12 oclock and the crank at tdc and it appears to be backfiring out of the carby
Posted: Sat Jan 23, 2016 3:32 pm
by Emerald8779
Did i mess up or is my distributor firing at the wrong times and igniting the fuel while that pistons vavles are kpened to exhaust?
Posted: Sat Jan 23, 2016 3:34 pm
by Emerald8779
Sorry i meant opening to fuel vavle
Posted: Sat Jan 23, 2016 4:32 pm
Sounds like the dizzy is 180 degrees out
Posted: Sat Jan 23, 2016 4:52 pm
by Sigmaproject
It will backfire and carry on even if it is only one tooth out on the dizzy.
Posted: Sat Jan 23, 2016 5:29 pm
by Emerald8779
How can i test that?
Posted: Sat Jan 23, 2016 7:04 pm
by Emerald8779
On top dead center on the crank markings, its on either fuel stroke or exhaust stroke, not compression stroke, does that mean i have wrong timing chain setup?
Posted: Sat Jan 23, 2016 8:28 pm
by Sigmaproject
You want TDC on the compression stroke. This is when the pointer on the front pulley points to TDC..and both valves for #1 cylinder are closed. TDC on the compression stroke the valves will be partially open. Once you have TDC compression stroke you need to find the marking on the dizzy for #1 cylinder. If you line up the dizzy so that it is at about the right angle to install in the head..just a bit right of centre near the cap mating surface you will find a marking that indicates the #1 spark plug lead location. To get the rotor to point to # 1 (around the 12'oclock position) after the dizzy is fully seated in the head ..you need to install it at the 2 oclock position. The gear on the dizzy will rotate it back to the 12 oclock position as you push it home. Install the rotor..replace the cap and If you firing order is correct..and you have fuel.. it should start.
Posted: Sun Jan 24, 2016 6:16 pm
by Emerald8779
Okay i tinkered about, it starts, but there seems to be squealing from the carby
Posted: Wed Dec 28, 2016 9:04 am
by leoca64
...BTW - How often should the timing chain be done on the 4G54 ?
Posted: Wed Dec 28, 2016 11:25 am
by Scorpma82
technically they never need doing
but for assurance......id check the tensioner every 12months...and replace the chain on every rebuild
