Exhaust compatibility between LB & LC
impulsive
Post by impulsive »
Hi all,
I'm wondering whether (as the LB/LC Lancer hatch was apparently based on the LB sedan) does anyone have any experience in swapping an exhaust from a LC hatch onto a LB sedan in terms of the floorpan being identical & everything matching up?
Thanks in advance.
Regards,
Impulsive
Re: Exhaust compatibility between LB & LC
Well, they have the same drivetrain and wheel base?
To my knowledge, the nose of the LC is longer, and the tail shorter.
It might work, but I can't promise anything?
It's nothing a half decent exhaust shop couldn't fix up on the cheap for you...
