Hey Guys,
The PWS project is slowly coming along. It now has no Front or Rear windshield and many other bits and pieces have been removed.
I was wondering if anyone would be able to tell me how to remove the dashboard? More specifically the top half.
Are the vents on the top of the dashboard connected to removing the dashboard?? If so how do they come off??
Any help and advice you can give me will be very appreciated.
Here are some pics of the dash and vents i am talking about.
Thanks,
Jasinex
PWS GH Dashboard
Re: PWS GH Dashboard
they should have bolts that feed through the metal frame under the dash with 10mm nuts on them, coincidentally that's what you will be saying trying to remove them. basically take out your air con/heater plastic vents get into the most uncumfortable position possible and with the smallest spanner you have try and reach under the dash and undo them. good luck I removed these on my GH scorp and hated every second. If you want pics of the vents out I can do that.
tubz
tubz
Thanks tubz,
If you wouldn't mind i would like to see the pics with the vents out.
Ill give it a try though next time i get around to working on it
Thanks for the advice,
Jasinex
Jasinex
