Page 2 of 4
Re: Galant E10 4G63BT, Project RALLI ART
Posted: Sun May 20, 2012 7:13 pm
by Tomica93
Posted: Tue May 28, 2013 5:31 am
by Tomica93
here is one update, i made an air box, 3inch intake pipe with K&N filter
Posted: Sun Jun 02, 2013 10:55 pm
by Tomica93
in a past few months a lot of work has been done
Megasquirt is installed now, finally, as i had MS1, it was converted to MS2 , with MS2 daughterboard and upgraded processor
FPR Aeromotive is installed, battery is moved to trunk, with 25mm2 cable
It has Eclipse coil ignition
Intercooler polished pipes
turbotimer hks
innovate lc-1 wideband
a/f ratio gauge, boost gauge and oil temp gauge
on CAS sensor it is now high resolution plate 24:1 tooth
shift light is also added
wiring a megasquirt2
it has great fetures now, such as launch contorol, flat shift, hope this week i will finish tuning the motor on the dyno
engine bay is now finished, this is a result
Posted: Mon Jun 03, 2013 1:50 pm
by geezer101
I always like checking out your progress on your Galant Tomica93 - this time around it looks like it's taken a big leap forward in development. It's also good to see that you're not scared of taking on the work yourself, the wiring alone looks daunting.
Posted: Thu Jun 06, 2013 3:10 am
by Tomica93
thanks, yeap this is a 12months of work, it was a little bit slow, but i didnt put here pics of many things i ve worked on it, hope i will soon go on a dyno and also be finished with this project, and drive finally
Posted: Mon Aug 19, 2013 1:10 am
by Tomica93
here car is finally finished
results
227,5 HP
348Nm
engine turned 125000km
Posted: Mon Oct 14, 2013 9:06 pm
by Tomica93
Posted: Mon Jan 20, 2014 9:18 am
by Tomica93
Posted: Mon Jan 20, 2014 3:22 pm
by geezer101
As always Tomica, nice to see how your Galant has evolved - but what happened to the rear end? Looks like you've had a bit of a push from behind
(and I like your car anyway but I don't do failbook...
Posted: Tue Jan 21, 2014 3:30 am
by Tomica93
thanks
yes i have an accident in july, only 3 weeks after i put it on the road again, a van hit me at the back
Posted: Tue Jan 21, 2014 8:17 am
by geezer101
...damn
Posted: Fri May 23, 2014 6:11 pm
by Tomica93
new engine has arrived, finally DOHC is going in
Posted: Wed Jul 16, 2014 1:34 am
by Tomica93
New injectors from EVO 4 , 510cc , with 69kkm
One picture in nature
and then there was a burnout with old engine
one video
http://www.youtube.com/watch?v=e3zZHIs6hL4
New alternetor for DOHC
After clening it up, and polishing a bit, here is a result
fuel line for DOHC
And then, a party time
next step was connecting a wires CLT, IAT , TPS and CAS sensors, CLT and IAT are the same, while TPS and CAS are a bit different
also, TPS needs calibration
one video after TPS was connected
http://www.youtube.com/watch?v=NekZojCvryw
CAS opened, and a 24:1 tooth is putted in
Friends are always ready
Engine in its place
Video of a first start
http://www.youtube.com/watch?v=zp9TLSSUqag
Compression test, by cilinders
1.145psi
2.147psi
3.145psi
4.144psi
and engine is putted on an homemade engine holder, to be easier to make a big service and cleaning it up a bit
Posted: Fri Aug 22, 2014 6:17 am
by Tomica93
First parts arrived
ARP head studs
set for balance shaft delete
injector rubber
oil filter x2
oil cap gasket x2
O2 housinga and downpipe 70mm gasket
Posted: Fri Aug 22, 2014 2:40 pm
by geezer101
You've been busy haven't you? And a second incarnation with a new engine! Looks like you have got bitten by the HP bug badly. Your Galant must've been a handful with over 220 HP up front.
Posted: Sun Aug 24, 2014 2:10 am
by Tomica93
yeah, those HP bugs are bad hahahah
iam doing my best, last turbo started to smoke on SOHC, and a new turbo would cost me about 600 dollars. and i got a complete engine for 1000dollars, so why not
and for the power, its a big and heavy car, i have 225/45/17 tyres and it almost never sliped in second gear(no LSD)
Posted: Thu Sep 18, 2014 7:11 pm
by Tomica93
Posted: Sat Sep 20, 2014 6:51 am
by geezer101
And so it begins again. Did you find a buyer for your last engine? The twin cam will take your project to a whole new level - can hardly wait to see your progress Tomica
Posted: Sun Sep 21, 2014 9:03 pm
by Tomica93
Yep , i have sold my last engine to Austria
i am also waiting for the progress, cant wait too see how it will run now with new engine
Posted: Sun Sep 28, 2014 5:37 pm
by Tomica93
Posted: Mon Oct 06, 2014 7:41 pm
by Tomica93
galvanized bolts, and lines
lines looks like they are cromed
and how it should looked on the block
Main water pipe is now rust free , and completely galvanized from outside, as well as inside
Posted: Wed Oct 15, 2014 5:01 am
by Tomica93
Just received a package
Mitsubishi Genuine parts
ACL Race bearings, Perfect Circle Rings
All parts collected so far
Rings
Posted: Thu Oct 30, 2014 10:00 pm
by Tomica93
sneak peak
Posted: Fri Oct 31, 2014 5:57 am
by geezer101
Nice work Tomica. Every time I check your progress you are turning it up a notch. Can't wait to see it back together.
Posted: Sun Nov 02, 2014 7:54 pm
by Tomica93
Posted: Thu Nov 13, 2014 4:58 am
by Tomica93
machine work done
honed and surfaced block, surfaced valves, surfaced head, and a polished crankshaft
how it should look when i will start assembley
then i got mitsubishi eclipse 3g lifters
difference between 1g and 3g
next is cleaning, and working on a port job on the oil gallery on the block (where oil pump sits), by that i mean on a smoothing the surface for better oil flow
Posted: Sun Nov 30, 2014 7:16 am
by Tomica93
Posted: Thu Dec 11, 2014 10:36 pm
by Tomica93
head on its place, torqed
thermostan housing, camshafts, lifters, rocker arms etc ,all in its place
its really nice to put all of those things together while they are so clean
thermostat housing
thread locker on the oil plug for oil gallery on the head
again another box is waiting to be galvanized, and iam wainting for another box of parts from America, hope that is the last one
Posted: Mon Dec 15, 2014 2:10 am
by Tomica93
Posted: Wed Dec 17, 2014 4:10 pm
by tandanus
Yowsers !
