Hi this one of my Bro's cars that we have been working on it's 1981 GH Sigma, we have just completed the engine install.
4G63 Starion SOHC
New Rings and Gaskets
Removed Silent Shafts
Sonata inlet manifold RWD modded with 60mm Magna TB
450cc VR4 injectors
Bosch 070 fuel pump
some rattly prime pump
Microtech Digi1 ECU
Standard distributor with Bosch ignition module
KLS T04e T3/T4 turbo (ebay special)
JJR 38mm wastegate (ebay special)
2.5" exhaust
a small intercooler with 2.5" SS pipes
2.6 5 Speed
Excedy HD clutch
It was a result of leftover parts from our other cars, and the sigma was registered, so after a bit of fabrication and engine rebuild. It has been a fairly low budget build, it's a fuel only computer which we have road tuned using our tech edge wide band, running about 12psi.
