GA Galant, 4g63t fitted and engineered! 151kw atw..
GLANT
Post by GLANT »
Lost pics on old thread so redoing another! :(
Here are some pics, they can tell a thousand words..many more to come! :thumpsup:
The car!
The motor! vr4 4g63 :thumpsup: :thumpsup: and the bits Ive modified V down here V
Did not like modified look of cast and billet alloy, soooo i painted manifold plenum in wrinkle paint then heat proof cast iron color!....^^^^
modified fuel rail, tapped thread one end, made adapter other end, because there was not enough material to thread!!!....^^^^^^
my water pipe....... thermostat housing deleted...run a remote thermostat housing in hose or..something???..CAS delete plug..^^^^^vvvv
air bleed niple will go to top of radiator....^^^^^^^
L300 sohc pump modified to clear cam belt...ce lancer pulley?..(had good offset), yep i know its 1 groove wider,im going to run front grooves only :)...^^^^^^^
sigma cross member with adapters to galant chassis rail mounts, which a remade and moved back a bit..^^^^^
accelerator cable mount working well! fuel rail in place....^^^^^^^
alternator relocation, left to right....^^^^^
modified left hand sigma engine mounts
wolf 3d ??? hope to run crank sensor on front pulley to run this computer..
WagonWheel
Re: GA Galant, fitting a VR4 4G63.......
Post by WagonWheel »
Dude, purely awesome. Normally i HATE pink cars. But thats not too bad. Definitely stands out!
davetrees
Post by davetrees »
Still running stock fuel tank ?
What are you using for a lift pump, and where have you mounted it ?
Dave
GLANT
Post by GLANT »
davetrees wrote:Still running stock fuel tank ?
Dave
Yeah still running standard tank, got a little rotor style pump ( like a mini bosch 066) straight of tank outlet ( one tight fit ), pumping fuel up into surge tank.
kenvv
Post by kenvv »
looks sweet in the first pic. looks darker and sooo clean. looks like your putting some decent parts in from the begining. good work
vrooooom vrooooom!!
davetrees
Post by davetrees »
GLANT wrote: Yeah still running standard tank, got a little rotor style pump ( like a mini bosch 066) straight of tank outlet ( one tight fit ), pumping fuel up into surge tank.
Any chance of a pic of where it's mounted ?
I'm figuring where to mount a similar pump (actually a low pressure Pierburg) in my car ...... but in theory they are supposed to be mounted "wet" (ie. below fuel level, I assume because they don't self-prime?) but finding somewhere it will fit but is reasonably protected underneath a rally car is a challenge !
GLANT
Post by GLANT »
used a long bolt through fueltank mount (from inside boot), to give me a stud to mount to...bent up a bracket to suit, cardboard one first :P ;-) and fixed with nut at one end and rubberized clamp at other fuel pump end! :thumpsup:
front of car <<<<<<<< outlet u turns at fittings,then goes up through floor into surge tank in boot!
front of car vvvvvvv
tandanus
Re: GA Galant, fitting a VR4 4G63.......more pics!
Post by tandanus »
Awesome.
:thumpsup:
T.
John Ruskin
Epic build :thumpsup:
I thought of this today: As for the CAS, is it possible to get a distributor based unit (like that in a Magna?).
(I know some of the Galant/Lancer owners retro fit later electronic internals into the distributors).
woops
Post by woops »
75wagon wrote:Epic build :thumpsup:
The biggest problem is getting a location on the twincam to actually put a dizzy. The only 3 real options are a trigger wheel on the front front of the engine, make room for the CAS at the back of the engine bay with a hammer (easy to do in the sigma, starion and a bit more difficult to do in the GC-GD galants) and finally the best but most difficult to find option is to try and find a front mounted RVR CAS.
davetrees
Post by davetrees »
Thanks for that .... helps a lot. Pump is almost the same as what I am using.
84GKSIG
Post by 84GKSIG »
hey mate great work, car looks awesome and looks as though it'll be great fun to drive too.. pink doesn't seem so bad now :thumpsup: whats the actual name of that color?
M.B :thumpsup:
GLANT
Post by GLANT »
color is P.P.P.... Petes perfect pink....lol! its a custom mix... :D :D
lchilds82
Post by lchilds82 »
dude this car makes me jizz everytime, if you ever want to sell it let me know
4GB63t
GLANT
Post by GLANT »
dummie fit up of turbo and standard manifold... on an upside down adapter :thumpsup:
the adaptor...easy!
makes all this a bit tight for exhaust....but doable! :think:
Update...easy fixed... swapped galant clutch cable for a sigma one and turned the cable around..adjustment is at bellhousing end now :thumpsup:
GLANT
Post by GLANT »
HOPE TO GET THIS GOING BEFORE XMAS!
THERE I HAVE NOW SET MY CHALLENGE! LOL!
GLANT
Re: GA Galant, fitting a VR4 4G63.......CONSTANTLY ADDING PICS!
Post by GLANT »
MY CUSTOM SURGE TANK
ISKA8
Post by ISKA8 »
i love it man,its tuff. :thumpsup:
MY NEW TOY F6310
tandanus
Post by tandanus »
Quote "makes all this a bit tight for exhaust....but doable! :think:"
Streuth - getting it past the clutch cable is one thing but how are you going to route it past the steering?
I dont doubt you'll find a way to do it but it wont be easy :D
I watched a former member making a 4 into 2 into 1 collector for a 2.6 in a GB. He ran an exhaust shop and spent months making it fit :thumpsup:
Top Project - love the updates :P
T.
John Ruskin
GLANT
Post by GLANT »
exhaust is just another hurdle to get over, in this project!! like the 100 already jumped..LOL!!... i will make a short dump pipe up, hopefully ill find a talented exhaust bender to join it all up! :thumpsup:
GLANT
Post by GLANT »
the manifold adapter 4g63, to turn standard manifold "upside down"
GLANT
Post by GLANT »
the "flip" adapter......
in her new garage, ready for more work.....and my scooter! :P
GLANT
Re: GA Galant, fitting a VR4 4G63t, 2 litre turbo.....more pics!
Post by GLANT »
turbo manifold - flipped and mounted up... turbo - clocked and mounted aswell..... wastegate - custom bracket and adjustable rod..
GLANT
Re: GA Galant, fitting 4G63t, 2 litre turbo.. pics! updated 10/5
Post by GLANT »
Image looking closer to finished!!
ted
Post by ted »
Holy shit Pete!!! Its fucking beautiful!!!!!
webby
Post by webby »
Not feeling the pink, reminds me of kebab-spec Autosalon shitboxes, but everything else gets a big :thumpsup:
GLANT
Post by GLANT »
webby wrote:Not feeling the pink, reminds me of kebab-spec Autosalon shitboxes..
LMAO!! yeah i know after having it this colour for nearly 7 years...its not everyones cup of tea!! but myself wanting a different colour than the norm...it works well! lol!
GLANT
Post by GLANT »
Image solid oil feed line...
You're obviously someone who 1: loves a challenge and 2: doesn't drop the ball when the game gets tough! My hat off to you, that is some seriously solid work. :thumpsup:
tandanus
Post by tandanus »
This is so cool (H)
I look forward to seeing how you thread the dump pipe past the clutch-cable / steering box / draglink :D
I have no doubt you'll find a way ......
T.
John Ruskin
