My GC Hardtop project
Re: My GC Hardtop project
While dicking about in the shed tonight I have decided the guard mounted indicators are staying on my new front guards.
already showed this to raptor, but thought youd find it interesting too
It's different. What car is it in?
Firewall has gone and the inner guards look GM but the plastic plenum and late model headlights through a spanner in the works.
honestly don't know
that h20 piping is most *ahem* unusual
I don't have a big problem with the re-routing of the coolant pipes for a RWD set up - BUT they're meant to be coolant pipes not heater pipes! Alloy piping that close to the extractors? The pic makes it look like the lower coolant pipe is literally sitting on #2 exhaust runner. And the power steering pump should at least have some heat shielding too...
Got my NOS GSII mirrors from Affa during the week and had to try them out right away, lol
Also got some badges from Affa, Galant and grill badges are for the A53, 5 speed one is from a GTO and for this car
What did you use to mount the badge ?
Came with double sided tape, no holes
Is that the 'factory spot' or is that just ur personal preference?
Can't find a bloody pic now but it think that is where they were on the GTO's and it is a perfect fit for the flat panel there, lines up sweet
- mrelshauno
They look different to the GTO 5 Speed badges from over here. I have a collection of badges downstairs. I will try to find and post later.
- mrelshauno
Can't seem to find them but wouldn't have thought that I would throw them out. Here are some that may be of use to members.
There is a break between the 2000 and GS.
Anyone from Melbourne coming over to NZ soon? I need a dash cluster brought over, any takers???
Scorpion diff painted up and fitted.
Did you really expect it to be anything other than red and white??
As you can see a stock width Scorpion diff is fine under a hardtop, even with my 15x8 +0's fitted with 205/50 15's
All I need now it the reset springs to lower it about 50-60mm and my limited slip center, which will also need to be painted, maybe red, lol.
I agree. The 5 speed badges that I've seen on GTO's are bigger and sit to the right of the left hand tail light. Maybe the badge is off an earlier A53C GTO which weren't sold in NZ.mrelshauno wrote:They look different to the GTO 5 Speed badges from over here.
1976 Galant Hardtop
Dunno really, or care now they are fitted, I like them
To be honest I think it looks better than the 5 speed badges that I've seen on GTO's.
1976 Galant Hardtop
Cheers, I like it. Looks factory enough the keep the 5.0 happy Now I need a twin cam badge an EFi badge and a 2.0 badge and all will be hunky dory
- mrelshauno
How does it feel with discs on the back now? Much improvement?
No idea yet mate, still be 5 or 6 weeks away from driving
A112H wrote: As you can see a stock width Scorpion diff is fine under a hardtop, even with my 15x8 +0's fitted with 205/50 15's
Obviously you had to fabricate spring mounts to fit this, how does your engineer feel about this? Also, how are you going to hook up the handbrake?
I remember reading from other posts that disc rear ends in Galants can be a little grabby, but nothing that some form of bias adjustment wont fix.
Engineer, BAHAHAHAHA you eastern staters make me laugh.
Handbrake from a GH is meant to fit straight onto the Galant handbrake.
I was thinking about changing the brake master with a 4 wheels disc master but may still need a bias.
We used the Scorpion cables for the handbrake and they work fine.
Scorpion or Starion master cylinders do the job nicely for the disc brake conversion and bolt straight onto the booster.
I see the front section of your leaf spring have that lovely wave shape they form from a bit of axle tramp. I used to be able to get an inch gap between the leaf with my old LA. Solved all the drama's when we linked the rear end.
Yeah, the springs have seen better days. Now having more power and more grip than it has ever had will be interesting, lol.
I will be getting new ones made by Industrial Engineers & Springmakers here in SA, they will also be stiffer and lower http://www.industrialsprings.com.au/contact.htm
I am interested in switching to a linked system like you did but it is a little outside my skill set and I don't have the cash at the moment to give it to someone and say "here, do this now"
I am selling the Hal-tech because it doesn't like aftermarket cam/crank sensors, I won't cut the firewall and front mounts are ugly, lol. So I have got a Wolf 3D so I can now run a crank pulley mounted trigger wheel.
http://www.sigma-galant.com/viewtopic.php?f=36&t=10325
Also, I got my JDM front valance in the mail this week
and have a tidy GC front bar on the way. So once I get the front panels all painted up and the plain front bar on it should be finished, should be
So does this mean you are going to ship your hardtop grill center piece to me, since you have that one?
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
Sorry Tim, that one is from the A53HRaptorReed wrote:So does this mean you are going to ship your hardtop grill center piece to me, since you have that one?
fyi gto 5spd badge
