HEMI26's dB Drag Scorpo
HEMI26
Post by HEMI26 »
Hi ppl i throught to thro my gj Scorpo build up here its a n/a build with most of my old gk scorpo parts (the body was stuffed on it) that was built at McDonald bros in Thomastown (Melbourne) by previous owner in 2001 and made 146.8rwhp on there dyno, with it hardly driven and a blown clutch setting around for over a yr i ended up buying it in 2003 and the engine gave way in 2005 when 3rd piston detonated. :banh: It was a good mid-high 14s car beating most stockish injected 5l up to 130 all day everyday.
my old GK Scorpo Mods were
-exshuast pacy's and 2 1/4' system
-wade cam unsure on specs
-astron1 head ported polished, oversize valves, double vavle springs, decked
-30" oversize forged high comp flat top pistons
-block blue printed, crack tested, bored and decked, o ringed
-balance shafts removed
-crank lightened and balanced
-oil pump
-rods shot peened
-new bolts all round
-weber down draft twin barrel reco'd + re jet'd
-inlet manfold ported n polished
-lightened flywheel
-heavy duty clutch (real heavy!!!)
-reco box
-custom 1 peace tail shaft made from a holden v8 one
-lsd 3.7
-new remapped dizzy
-pedders springs and shocks
being young and a dumass i left the block out in the rain leaving internals stuffed (crank,rods n stuff) :facepalm:
any way here's some pic's of them,
i since got my self a gj scorpo in vgc not runnig, with a few body mods (no side strips etc) and no rust, great clean interior, full exhaust system, 5spd with an m1 head astron 2 engine (H) at the end of 2009 reason it wasnt runnig he was going efi, since i've had it i've put my old head, carby, fuel system and dizzy on the stock astron 2 block, changed the suspension, 1 peice tail shaft, put new bushes all round and thats as fair as i got. i still need to get the lsd reco'd.
Current Cars
-VQ SV90 #098 (Finished)
Some Old cars
-RX8
-VQ (Slammed on 19's)
HEMI26
Re: My Old n New Scorpo
Post by HEMI26 »
Pic's of the R31 Cepters on the scorpo
Just need to put some 205/60/15's on the front as the 225's are a little big :(
Current Cars
Some Old cars
-RX8
TVM006
Post by TVM006 »
Looking forward to see some sweet progress! :thumpsup:
TVMDouble0h!Sixx
1985 GK GSR
HEMI26
Post by HEMI26 »
some interior shot's
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
Some pic's of my 2nd Scorpoin i found...
Current Cars
Some Old cars
-RX8
HEMI26
Re: Scorpo from wild n/a to turbo (building the parts up)
Post by HEMI26 »
just a update i picked up my evo injectors yellow tops with 2 squirters theres a few no.. on them and unsure the part no.. they are 510 , 019 and 932 and evo rail today :D and the blown evo block up tomoz (H)
does any ony kno wat size injectors these are?? its a early evo it came off :D
ill get some pics up soon off the parts i got so fair :thumpsup:
Current Cars
Some Old cars
-RX8
woops
Post by woops »
I'd say that they are a 510 cc injector. I'm pretty sure that the denso injectors actually have the flow rate listed on part of the injector. I have some evo yellow tops which have 510 and some vr4 blue tops here with 450 on it and that corresponds to the listed specs for those vehicles. Even the sonata's list something like 275 or something. Although i got my 450 ones flow tested and i'm not entirely sure if that is an actual flow rate. I'll see if i can find the flow data sheet.
The evo yellow tops i have the part no of INP-015 and on the other side of the injector has B510L which corresponds to the flow rate quoted by most people. Although mine are only a single pintle injector. I think the brown tops which are from a RX7 are a 550cc injector which is the largest compatible factory flow rate injector. Any higher and you need to go aftermarket injectors.
sceneybr
Post by sceneybr »
hey quick question bout the r31 interceptors i had a set of 4 for my sigma due to a slight bulge on inside of the rim i couldn't fit them properly on my sigma are scorpion hubs different?
HEMI26
Re: Scorpo from wild n/a to turbo (on the road wed but n/a)
Post by HEMI26 »
cheers for that woops
sceneybr wrote:hey quick question bout the r31 interceptors i had a set of 4 for my sigma due to a slight bulge on inside of the rim i couldn't fit them properly on my sigma are scorpion hubs different?
i had no major probs but they were a tight fit on, just that the tyres were to big on the front i havent drivin on them yet but thinking of machining out the center i little so there no a tight fit on the hub like they were (eg ve 16" on pre ve vn-t etc)
Current Cars
Some Old cars
-RX8
Sigmoe
Post by Sigmoe »
shes gonna be pretty mean man! cant wait
HEMI26
Re: Scorpo from wild n/a to turbo (on the road on wed)
Post by HEMI26 »
Scorpo will be out on the streets on wed when i get my plastic back!!!
on a permit tho :( have to get reg but its not far off :thumpsup:
Current Cars
Some Old cars
-RX8
ISKA8
Re: Scorpo from wild n/a to turbo (on the road wed!!!)
Post by ISKA8 »
hey dave,the scorp looks sweet in the pics but looks even better in the flesh.cant wait to go cruisn together once my cars painted buds..
oh yeah,hows my rx3 goin.. :P i want that car man!!
when your baby's on the road just come past my joint and we will talk some shit.. :lol: :thumpsup:
MY NEW TOY F6310
HEMI26
Post by HEMI26 »
ISKA8 wrote:hey dave,the scorp looks sweet in the pics but looks even better in the flesh.cant wait to go cruisn together once my cars painted buds..
still needs paint tho man whom ever done it done a bodgy job :P , n yer cant wait to go cruzin wit some 4g's (H) will be good!!! :thumpsup:
on the topic about paint do u kno any good sprayer's as im looking at goin fire eng red, but there's a few other colours in my mind aswell :think:
n yer she's goin good on the topic of paint again needa do that this yr to :lol:
and shore thing will catch up soon now i got my plastic and talk alot of shit :P
Current Cars
Some Old cars
-RX8
HEMI26
Re: Scorpo from wild n/a to turbo (on the road!!!)
Post by HEMI26 »
Had here out the hole day today running the high comp set up on a cover note went really good (H) ,apart from a clunk i discovered in the pass side front end one more thing i have to do before reg :(
Current Cars
Some Old cars
-RX8
HEMI26
Re: Scorpo tuff n/a soon to be turbo
Post by HEMI26 »
few more probs have poped up te last 4 days, clunks in the front ends, alternator went :( lucky i have a few :thumpsup: and i might have a water leak as i have a over heating prob the water pump and i found a tiny bit fof rust underthe pass door :@ apart from that shes goin good :P
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
found the water leak it was the heater core the one part i didn't take off the gk :(
alternator fixed (R31 TI 70amp one moked up) :thumpsup:
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
I by past the heater core hoses and no more prob's damm!!! it bein winter tho :@
also i think my thrust bearing is on its way making weird noises sometimes :(
apart from that haven fun showin the young ones the high comp n/a scorpo is quicker than there commonhores :lol:
Current Cars
Some Old cars
-RX8
TVM006
Post by TVM006 »
'apart from that haven fun showin the young ones the high comp n/a scorpo is quicker than there commonhores '
I LOVE THIS hahahaha! (H)
TVMDouble0h!Sixx
1985 GK GSR
HEMI26
Re: Scorpo h/c n/a soon to be turbo
Post by HEMI26 »
well time for an update i think
well i clicked over 1000k's in the scorpo the last few weeks on a cover note while getting my daily up and running gave her a full service, new chrome air filter, painted the rocker cover black to get rid of the gold theme the brown 1 had, sterio back in as i sold the one i got with it :P and i got a few probs i discovered before the main build thank god :P which were,
front left ball joint
alternator (fixed)
thrust bearings ok thought it was going but i'll replace anyway
heater core so i'll need to pull the dash out
not much but least i'll know i don't have to do them again and i've had a plan change as im thinking of going efi before turbo and see what i can get out of her h/c hopefully more than my old gk :thumpsup: also it will be alot easyer to go turbo the way i want it, as i want to get it reg'd before turbo
also been thinking about a nissan blue bird diff conversion as i got a lot of parts from my other cars (gears, lsd centre's ect) + easyer to rebuild when it goes bang :think: and a z31 brake upgrade
sorry but i got no camera atm but pic's up soon of my progress ppl :thumpsup:
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
some pic's up of the parts i sold...
most the turbo set up...
new turbo cam, gaskits, spacer plate and evo injector's (still need to pick the 4g63 block up)
just noticed today that the exh manifold seem's to be ported and polished :D
2.5" n 3" dump pipe, sump, heat sheild's and bonnet vent's
turbo parts, sensors, a few bolts, turbo lines, dizy, turbo oil pump modified and ebay turbo + parts (mates old turbz)
Current Cars
Some Old cars
-RX8
ISKA8
Post by ISKA8 »
looking good bro... :thumpsup:
hey you still have those cepters?i need some.also the sh bonnet vents,did you want to sell them?
MY NEW TOY F6310
HEMI26
Post by HEMI26 »
ISKA8 wrote:looking good bro... :thumpsup:
cheers harry
yea still have them there hard to get unless u kno some 1 with em there r31 spare rims, n na soz i got them off antother mate who had a esp turbo shell
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
updated pic of the eng bay :thumpsup:
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
Just an over due update :$ , havent had much time to work n stuff on the scorp due to the SV (Thanx ISKA8 for the Help!!!), but i have some founds put away due to selling my genuine Rx3 Coupe :( so i'll be getting some over due body work done real soon make it look the part 1st before she hits the road :D
Dave M
Current Cars
Some Old cars
-RX8
HEMI26
Re: HEMI26's Scorpo
Post by HEMI26 »
Long time since i've been on here but i still have my scorp and looks like it'll be my new dB Drag comp car updated pic's will be up soon but will be at some car show's coming up.. on the 1st sep @ Caribbean Gardens then the 14th-15th @ Sandown Race course
Also i hold the loudest Stock Trunk in dB Drags in Vic atm :thumpsup:
My profile http://www.termpro.com/asp/competitorst ... Method=101
My stat's http://www.termpro.com/asp/competitorst ... 3&Method=1
just needing a ps pump as i sold mine to harry ISK8TE to help him out at the start of the year :z if anyone can help us out with one it would be great :thumpsup:
I also got a hold of a GJ Galant Turbo off Lomian (H)
Current Cars
Some Old cars
-RX8
HEMI26
Re: HEMI26's Scorpo
Post by HEMI26 »
thats 4K rms over 12000 Watts peak going into the scorp... :thumpsup:
Current Cars
Some Old cars
-RX8
HEMI26
Re: HEMI26's Scorpo
Post by HEMI26 »
Went for club reg this today and passed np's :thumpsup: ill be picking the plates up this wk :P
Current Cars
Some Old cars
-RX8
theozsnowman
Re: HEMI26's Scorpo WTB A P/S PUMP ASAP!!!!
Post by theozsnowman »
Looks great
Im curious about Club Reg.... are there any vic roads acreddited Mitsubishi clubs out there or are you a member of a general club?
Ive being trying to find out if there is a way to get mine Club Registered as i will only be driving it every now and again to show and shines and the odd run...
My 1980 GH Scorpion Restoration Project - The Oz Snowmans Scorpion - Meet B1 and B2 - The Grey Ghost
HEMI26
Post by HEMI26 »
theozsnowman wrote:Looks great
Cheers man :thumpsup:
Same trouble as i was finding a club aswell, i joined a Rod & Custom Club for mine thats pretty local for me but i'd say any old Chrysler Valiant Club should exept sigma's ect as they were Chrysler and Dodge in the US...
If interested send us a pm and i might be able to help out :thumpsup:
anyways here is a pic with them new club plate's (H)
Current Cars
Some Old cars
-RX8
HEMI26
Post by HEMI26 »
Some pic's of whats done so far... :thumpsup:
Current Cars
Some Old cars
-RX8
