Page 3 of 4
Re: 1972 GB4g63t BUILD
Posted: Wed Mar 30, 2011 10:56 pm
by lchilds82
74GalantGB wrote:Gonna sell it when its done ? >.>
Sigh... *wishes* heh...
What's left to do ? =]
wont sell it for along time if ever but whats left to do heaps.
To start with im trying to change as little as possible to get it on the road this way i wont need enineering certificates for so many things at once and less likely to get knocked back for rwc, so to get it on the road i still have to get the water piping at the rear of the engine fabed up, get all the brakes rebuilt, new fuel system(surge tank etc.), intercooler piping and exhaust made, new rear suspension, all the wiring needs to be done to the microtech computer, and some interior work. more body work and full paint job.
what ill be doing in the future after getting it on the road is, supra gea box, hilux diff with rear brake setup, and better front brakes(skyline or something)
So still lots to be done
Posted: Mon Jun 13, 2011 9:48 pm
by lchilds82
finally geting back into some of the build start of thermo housing relocation
Posted: Mon Jun 13, 2011 11:03 pm
by ISKA8
she is coming along nicely buds..
Posted: Mon Aug 08, 2011 6:32 pm
by lchilds82
update long over due, engine is in and looking good
im looking at different ways to route the water lines and stuff but think im pretty set in the way i want to do it
inlet plenum want be staying unfortunately, it is to close to the lights with the throttle body on, will look at modifying later but for now ive picked up a standard one thats been modified
clearance is looking pretty good atm, hopefully dont run into any unexpecting problems fron here
getting there
turbo and water plumbing will be next on the agenda
Posted: Mon Aug 08, 2011 6:41 pm
by dvsfin
do you mind if I ask where you got that inlet manifold
Posted: Mon Aug 08, 2011 7:37 pm
by lchilds82
of the net, a random buy that came up, looks really good, but will have to use a standard one to start with or i might sell the custom one see what happens
Posted: Mon Aug 15, 2011 7:13 pm
by lchilds82
Posted: Mon Aug 15, 2011 7:39 pm
by lchilds82
not my idea but a very good one
Posted: Thu Aug 18, 2011 3:53 pm
by lchilds82
ok so flip flop manifold adaptor worked well and cost me 30 bucks to make, next thing im goin to work on is the water plumbing
this is how i think it should flow, let me know if i have got it wrong
i know it looks like a 5 year old been on microsoft paint... lol
Posted: Thu Aug 18, 2011 11:35 pm
by GLANT
Posted: Thu Aug 18, 2011 11:48 pm
by GLANT
I was worried about the head not bleeding out the air trapped in it...water will flow down under manifold to rad...but not the air...so i put small air bleed hose from head outlet to rad (or thermo at rad in my case)..
from nipple here at top of adapter
to nipple here at thermo housing (you can see the 8mm hose to left of pic)...it should also provide some recirculation around thermostat to aid in opening it...
Posted: Fri Aug 19, 2011 3:23 pm
by lchilds82
thanks for pointing that out wouldnt have though about that other wise, what if i just taped a bleed screw in to the pipe at the back, so open the screw slightly with the engine running to bleed the air out?
This is sorta how i remember my rb20 engine bleed the air out
Posted: Fri Aug 26, 2011 2:46 pm
by RaptorReed
You could delete the water lines to the turbo if you wanted to, they aren't really necessary, Mitsubishi did it to prolong the life as the average consumer isn't a enthusiast like ourselves and would just shut the car off after a long period or hard driving in the car. Just install a turbo timer that way when you go to shut off the car, it will stay running for another 30-60 secs to allow the turbo to spool down then shut off on its own.
Posted: Fri Aug 26, 2011 9:31 pm
by lchilds82
Thanks for the input, see how i go but i already have the parts to keep the water for turbo so probly well keep it at the moment.
started on exhaust system
Posted: Sat Aug 27, 2011 11:13 pm
by lchilds82
my dumpy i made this week, come up pretty good for a first attempt
trial fit, very close to the clutch cable, will have to make heat shield and try to get the clutch cable as far away from it as possible
Posted: Wed Sep 21, 2011 4:17 pm
by lchilds82
Posted: Thu Sep 22, 2011 1:28 am
by colta51
wow i havnt had a read of this in a wile and its cuming along great man well done!
Posted: Fri Nov 25, 2011 10:00 pm
by lchilds82
im so stocked just landed me a much better condition GB then what i already have, i bet there was a few of us on here watching this baby on ebayhttp://
www.ebay.com/itm/170732845520?ssPageNam ... 500wt_1156
so cool
my plan is to get this on the road and drive it while i continue work on the red one and then when its all sorted transfer it all to the green one, probly respay in the original green
any way yewwwww
Posted: Wed Nov 30, 2011 2:06 pm
by lchilds82
created a facebook page for all my updates click here
http://www.facebook.com/pages/1973-Gala ... 112?v=wall
Posted: Sat Jan 28, 2012 3:19 pm
by lchilds82
ok update time, the red galant getting the conversion done on it has had the microtech 90% wired in, water piping just about there, but on a bad note i have tried to crank the engine to see how its going and the starter motor doesnt make contact with the flywheel(doesnt engage) i tried all 3 starter motors from the 4g63, the 4g32 manual and the 4g32 automatic( they all look pretty much the same) all with the same result. i used the standard 4g32 flywheel as im starting off using the standard 4 speed. So had to do some searching for what i should be using and apparently i should be using the front wheel drive 4g63 version as it is slightly bigger, will swap them around this week and hopefully that is the end of the dramas with this, also scored r31 diff with rear disc, tail shaft and front brakes which will all be added to the car down the track. still not 100% sure on which transmission to go with yet, would a power glide fit under there i wonder, anyway thats where its at.
Posted: Mon Jan 30, 2012 6:59 pm
by Tj.
Have you been able to track down a flywheel yet? One thing to keep in mind is that the RWD '63 flywheels have a bearing in the center for the input shaft in the gearbox where as the FWD doesn't. It just has a hole that is pretty much the exact same size as the input shaft on the standard galant gearbox.
Posted: Mon Jan 30, 2012 10:04 pm
by lchilds82
Mate this is driving me crazy, took it all off today and compared it to the 4g32 flywheel and the 4g32 is noticeably bigger, so done some research and l300 express seems to be what i need, so will chase one up and hopefully will be all good. Glad i found this now though..
Posted: Mon Jan 30, 2012 10:07 pm
by lchilds82
also i didnt use the 4g32 flywheel
like i thought its only 5 bolt not 6
Posted: Fri Feb 03, 2012 9:07 pm
by lchilds82
ok so rang around looking for a rwd narrow flywheel, with no luck
so decided to go to the local wreckers to check what they had, looked in the Mitsubishi section and found nothing that looked similar with the 6 bolt pattern, so i had a look at other sections and came accross one that look identicle to my standard 5 bolt flywheel except with the 6 bolt pattern that i need, all i know is that it was in the nissan section and had 4x4 on it
. So now ive taken it home and got it on the car all thats left to do is try the starter on it and we are good to go but yeah like i said its identical in size to the 5 bolt standard 4g32 flywheel, i'm thinking that it might have been in the wrong spot and may have been a Mitsubishi one of some sort. Once this is out of the way might be on track to get this thing running
Posted: Tue Feb 07, 2012 4:03 pm
by lchilds82
well the flywheel that i eyeballed from the wreckers seems to work a treat, does anyone know if nissan shares a fly wheel, maybe a smaller truck...
now the count down begins for getting this thing running
Posted: Thu Mar 15, 2012 4:47 pm
by lchilds82
getting there
Posted: Tue Oct 16, 2012 6:04 pm
by lchilds82
got her running today, which is an awesome feeling after wiring the microtech in for the first, now its time to pull it all out and put it into the good one...
AWESOME
Posted: Tue Oct 16, 2012 6:11 pm
Posted: Thu Oct 25, 2012 7:08 pm
by lchilds82
Posted: Tue Nov 13, 2012 6:04 pm
by lchilds82
