A bit of an update (although pathetically small).
I had to go to the tyre place today to get a screw removed from Mrs 75wagon's Lancer. So I thought I'd get the tyres removed from the 13x6 Hustlers while I was going there, so I could start polishing them.
BTW, yes these 13x6 inch wheels do fit over the 2.6 Sigma struts, I just have to trim one part of the dust cover behind the disc (It just rubs). I think the offset helps them clear more then anything else?
Let the polishing begin.
Just to let you guys know what direction I'm going with this, my plans are to fit the 2.6 Astron 1 I have managed to get hold of, and fit a TR/TS Magna head and EFI setup. I know this requires reducing the height of the intake down to clear the bonnet, that's fine. I also have been told I need to fit dome top pistons to bring the compression back up.
I also managed to get some GK Sigma struts to finish off the stuff I need. The engineer said I need to match the brakes of the Sigma that the motor came out of. I'm in luck, I have a spare Galant wagon rear axle and the rear drums on that are larger then Sigma sedan rear drums, so I can just use them. I've been told the wagon drums are just a bolt on job, I suppose I'll find out in time. I might even just use the whole wagon rear end.
I'm still time poor, but the house renovations should be finished soon enough I hope, so then full steam ahead.
When this starts I plan on picking up a running TR/TS Magna (so I know everything works) and then transplanting everything across the the Galant. I plan to just keep it all standard, it's only going to be my daily, plus I think the power increase from the Saturn should be enough for my lead foot.
