My MA L200 ute
My MA L200 ute
I know I know! "Another build?!"
Here's my recently acquired l200 ute. I bought it from a fellow member (thanks Shaun! ). It has no engine or box, no tray and no seats.. So a perfect start for me! She's a bit rusty but nothing compared to most of the ones I've seen! (Front of the sills and front quarters. That's it)
My plans are;
Race seats
4g63 dohc efi from a gsr galant
5 speed
Exhaust system
Lowered about 2"
Custom tray
D shaped steel rims in black. 16x8 -34
(Here's the bit some will ask "why")
Fender mirrors
Zg flares up front
Stretched tyres (not a lot)
Gonna try and sticker bomb the rocker cover
Rising sun (jap naval flag) for a roof lining (another see how I go thing)
And MAYBE! A ge front
I'm not going to be repainting the ute at all.. I will fix the rust, spray over it in black, and leave it.. Going for a rough jdm mini truck theme
Now for the pics! Lol
Going to be a daily.. So nothing too exciting.. just a efi dohc g63 ;)
Cheers,
Mick
My plans are;
Race seats
5 speed
Exhaust system
Lowered about 2"
Custom tray
Fender mirrors
Zg flares up front
Cheers,
Mick
Re: My MA L200 ute
At least currently it is not smokey, and no nasty noises from the gearbox, huh?
Should be a great build
Re: My MA L200 ute
Looks good, great place to start and your plans are perfect, will look tough. Factory A/C by the looks?
Pretty sure that was a factory 4G32, will rego be an issue with a 4G63 in it?
Re: My MA L200 ute
Oh flash one! Air con
And nah because the same chassis came out factory with a sohc g63.. As far as they know.. I could've just replaced the head with a dohc ;) see how that goes if I get pulled up, I'll play dumb and I suppose I'll go see an engineer.. It won't be a hassle as I will be using oem mounts and so on. Tray may need a tag, as will the seats.
But thank you for the kind words
Oh and flashy, SO FAR, there's no rattles or clunks I haven't seen this galant yet. And for $500 running I'm not expecting much.. But time will tell
Re: My MA L200 ute
Yep, these came sohc G63B from the factory. I spied this on youtube a little while ago, this could be an option... http://www.youtube.com/watch?v=FVpbeTobo-c. By the looks of it you won't need to fool around with modifying the inlet manifold to suit a RWD application.
Re: My MA L200 ute
I can't watch all that one sorry need credit for you lot! haha..
Any chance you could sum it all up? I watched 5 minutes and Telstra screamed at me
Re: My MA L200 ute
O.k. here's the synopsis. Guy buys a Kia Optima minus the drivetrain and has a look in the local wreckers. After a bit of research and using his own knowledge discovers the Kia is sharing a heap of mechanicals with Evos as the engine was built by Hyundai with a few very minor differences, so it could either be used for replacement parts on the cheap for Evo's or leaves the door open for upgrading to turbo by using Evo stuff. The engine is a 4G64 2.4 litre engine with a 7 bolt crank. Near identical head, same block, same gaskets, same bottom end. The bottom end could be pulled out and swapped into a 4G63 as a stroker engine. The added bonus is the throttle body is already front mounted so no cut and shut welding. If this is all correct it could make this a viable engine upgrade.
Re: My MA L200 ute
So.. Can I use the throttle body from it on my 63?? It's from a gsr galant
Re: My MA L200 ute
Make sure you double check before you buy anything from a Kia. Lots of there stuff is very closely related to a 4G63 BUT, they mainly used EvoIV style heads. So the manifolds are on the wrong side for us.
Re: My MA L200 ute
Nah I'll just stick to what you guys know thanks though
Stopped into the panel shop on the way home.. Gonna get the guys to have a look at her.. $90/hr..
Re: My MA L200 ute
The bodywork is the single most expensive job you can outsource on a car. Do whatever you can before sending it off for a paint job, it'll put cash in your pocket. What colour are you painting it in?
Re: My MA L200 ute
Yea the only stuff they'll have to do is cut out the metal and replace it.. There will be no rust in it when it goes.. It will be treated..
And as for colour... It's staying as it is..
If you ever read the 240z build in the "inspirational builds" topic.. I'm going for the look he had, before it was painted.. A little rough to look at. But it's not too rough.. So it's still passable... If you know what I mean??
But of I end up going with the ge ute... It will go purple.. Most likely. See how I go
Re: My MA L200 ute
Update; I'm going to bring her home tomorrow!!! Then it's saving for the gsr galant, then the body repairs.. In between times... I shall treat the rust so it doesn't spread, and pick up little bits and pieces I will need.
Re: My MA L200 ute
Looking good, cant wait to see the end result
Re: My MA L200 ute
haha, anytime man, let us know if you want a hand with neautralising the rust. after my VG i have gotten half decent at it
Re: My MA L200 ute
Photo dump!!!! (this is gonna take forever via mobile!!! Lol)
First up.. I'll post the good
http://photos-d.ak.fbcdn.net/hphotos-ak ... n.jpg?dl=1[/img]
People have showed up for my party so I shall finish it later but there's a tease
EDIT: I've tried fixing the last pics, they won't work... Please can someone fix it?
Re: My MA L200 ute
Had a look over/offered some help with this today. its a good ute for what it is, and will be awesome once its all done
Re: My MA L200 ute
Thanks jase! see how straight she is!?
And thanks for your help today Jon!! Was good having company
Hope to get more done ASAP!!!
Re: My MA L200 ute
Small update;
Going to pick up the donor car today!
I have done a fair bit of work on the ute, but I'll update with pics when I'm home and have 3 hours time to post all the pics
Re: My MA L200 ute
New addition to the family!! A 1989 HG GSR galant hatch. (Aka, donor car )
I drive it home tonight, with a broken gear selector.. So I had.. 1st
Also had no indicators
But that thing is flash!!! All windows work, nice interior, and it has this wicked genius electronic suspension!! With 6 settings (soft, auto or hard.. Which all have a setting of soft, medium and hard.) it was set on soft, so I pushed auto and because it was up around the 4500 rpm mark, it set the suspension hard, and within a second or two, it was rock solid! Bouncy and everything! I could've reefed on the wheel hard and it would've had no body roll! That, is cool!
Anyway, the engine is good, so let it all begin!
Re: My MA L200 ute
yep! Mum reckons the gsr is too good to wreck.. All it needs is indicator bulbs and a linkage, and it is a roadworthy, reliable car.. Lol
Re: My MA L200 ute
yeah but its FWD, not anything against newer mitsu's but the only mitsu of that style/era i would save would be a GSR Lancer (AWD) seen them with simple lowering and wheels and they look awesome
Re: My MA L200 ute
Yea I'm the same.. Should be fun hey! Any chance I could borrow that crane when I need it?? If I don't buy one
Re: My MA L200 ute
which one, the 2.5t one in the shed is stuffed (hydralic seals need replacing) and the one we used on my car was a mates fathers
