Page 2 of 2
Re: 2 door LA build-hillclimb car
Posted: Tue Aug 21, 2012 8:56 pm
by krohny
Alright.. Dash is back in, all lights and tacho working finally
Posted: Sun Sep 16, 2012 6:09 pm
by krohny
Finally got around to putting the fuel pump in the boot, now I just have to put a cage around it and it passes roady apparently..
Posted: Mon Sep 17, 2012 10:59 am
by JimmyG
May be worth fitting a rubber sleeve around the two hose's where they go throungh to body. Vibration and time could cut into them and fill your boot with fuel. I would also seal the gaps that lead from boot to cabin as you now have fuel systems in the boot space.
Humans on fire = :(
Posted: Tue Sep 18, 2012 9:39 am
by krohny
Yeah, I have the grommets at home already.. The boot is sealed off only by the seat and wooden panel, both which burn quite easily..
Will fit a metal sheet when time permits.
But cheers!
Posted: Tue Sep 18, 2012 7:05 pm
by davetrees
Have you got a filter in between the tank & the pump ? If not, then I strongly recommend you fit one ..... it's more important there there than between pump & carbs
Nothing worse than having the car grind to a halt because the electric pump has ingested some crud from the tank - they are less forgiving than mechanical ones (even the factory setup has the filter before the pump !)
Posted: Tue Sep 18, 2012 7:16 pm
Yes, yes and more yes you will need a filter between tank and pump as well as pump and carbs.
Also, go into your local air conditioner installer and ask for a but of cut off "waffle pad". Bolt it between the pump and boot floor, it will make the pump last longer and reduce the noise these little buggers can make.
This is how mine is set up, the big red canister is the filter :thumpsup:
Posted: Tue Sep 18, 2012 8:21 pm
by davetrees
...... as well as pump and carbs
There's actually no value in having a 2nd filter on the carb side of the pump (IMHO) ... unless of course your fuel lines are full of crud, in which case you should clean them !
Posted: Tue Sep 18, 2012 8:22 pm
Fair point, I don't as they are all new but other may have used some old lines.
Posted: Tue Sep 18, 2012 9:47 pm
by krohny
Thanks for the advice guys.. I already have a plan to minimize the pump vibration, I'll have to fit a filter before the pump, I have the one that came with pump somewhere..
Also just fitted a coolant bleeder, I figured there would have to be air getting trapped in the hight point of the hose
Posted: Wed Oct 24, 2012 9:14 am
by krohny
A little more progress.. got my suspension sorted, will hopefully fit it tonight if I get time.
Also have 3" blocks to fit to the rear then have to check clearances and work out what else will need to be done
Posted: Thu Oct 25, 2012 6:34 am
by BIG26L
Why didn't you just put the fuel pump under the car???????? Then you don't need a cage over it for rego!
With the way its currently set up, your in for some drama's.......... When the tek-screws loosen and the pumps starts moving around, A) the pump start working intermitently and B) when it does work the vibration will wear the fuel hoses against the bodywork and you'll have fuel all over everything including the hot exhuast under the floor.
I hope your extinguisher isn't screwed down with tek-screws as well!
Posted: Fri Oct 26, 2012 8:59 am
by krohny
Easy tiger.. it's just tech screwed in for placement. I'll fit grommets around the hoses and a foam square under the pump and bolt it in.
There isn't much room under there with 3" lowered suspension, and well.. I wanted the pump in the boot.
Posted: Fri Oct 26, 2012 9:20 am
by Scorpma82
as long as it's securely fitted and protected...you can have it on the rear parcel shelf if you wanted.....not a practical spot...but u get my drift lol
