Great,the motor is running...although a little roughly.Its a bit loud though,suppose it does have the 3 inch exhaust...no turbo now it was to be expected .
Yep she would idle and nothing else initially.I would try to rev and it would die...You really need to keep the stock TS/TR airbox with the loom and all the sensors when you do it.
I am pretty happy with where i am at.LC Lancer with turbo less JDM 2.6 Starion engine ,custom extractors, and full 1996 TS Magna Multipoint EFI (except for the plenum itself)...Should be able to get registration now after the modification check.
Things needing to be done.
1.The clutch doesnt engage ...unsure of why..cannot drive it at all.Does it need a rebuilt slave cylinder?
2.Bad water leak from heater, even when off.
3.Thermos need connecting up to automatically operate when required.
4.Fix the centre console.
5.Finish interior.
6.Have airpipe made for stock airbox.
7.Wiring to sort out ...losing ignition on start.
8.Why doesn't the ECU run the fuel pumps?.
9.LH brake light stays on all the time???
10.Panels and paint.
...wow there are a few things still hey!
10 plus "X"
.Enjoy ,power to weight ratio should be greater than in my Starion
