Sigma GK GSR daily
geezer101
Re: Sigma GK GSR daily - project SC14
Post by geezer101 »
Maybe out of a diesel? I think old galants ran a brass mesh strainer. Time to do some site surfing! Bound to dig up something locally...
GC75
Post by GC75 »
I may go pick a part and see what i can scavange up :)
webby
Post by webby »
I think I read somewhere that the EFI filters will starve a carby engine of fuel due to the greater pressure required to push the fuel through it.
Don't quote me on that, but it might be an idea to get a low pressure electric fuel pump just in case :thumpsup:
ISKA8
Post by ISKA8 »
hey buds i figured out the problem(s) with my car...turns out the vacuum hose from the ecu to the plenum wasnt connected,2 injectors needed replacing and also needed new plugs. :thumpsup:
hope you figure out the issue with yours bro!
MY NEW TOY F6310
81GL
Post by 81GL »
webby wrote:I think I read somewhere that the EFI filters will starve a carby engine of fuel due to the greater pressure required to push the fuel through it.
Agree with that.
Is the car together enough to make it run? Get some fuel hose straight from the pump into a jerry can.
geezer101
Post by geezer101 »
Aren't you already using an electric solid state pump? Thought I saw it installed low down next to the strut tower...
GC75
Post by GC75 »
@webby - Yeah ur right, was running fine even with mech fuel pump before all the troubles arose though.
Also got an elec fuel pump and a regulator so should be right with the pressure right??
@ISKA8 - Hmm vacuum might be worth going over then, should be right though.
i shall get there :thumpsup:
@geezer101 - Yes i am but, got a fuel regulator that i can adjust the psi with a valve, so ain't over pumping, but then again i haven't checked the pressure, was going to still might have to... :wut:
geezer101
Post by geezer101 »
Might have made a comment about the front carby having a bung screwed in where the fuel outlet should be- if there was an outlet and hose to the tank return line shouldn't that eliminate or at least reduce over pressurisation? Was running a carter pump on my carby'd colt and didn't have any issues with over pressurisation...
GC75
Post by GC75 »
Yeah there was, didnt end up doing that though.. :\
The simpler the better if it works then no need for the regulator.
geezer101
Post by geezer101 »
Simple works- the more stuff you add the more difficult it gets to diagnose problems. I prefer old school neanderthal tech, points, plugs and carbies. Mind you a EGO sensor in the exhaust and a jaycar EGO tester kit makes adjusting carbs a whole lot easier! 8-)
GC75
Post by GC75 »
Yup to right, and cheers for the advice.
played round with the tank again today, fitted new lines, and ran a filter between the tank and the metal lines... until i source a new tank with working float etc...
Now waiting for my battery to charge then im going to run it without the metal filter and regulator and hook up the return line and see if that works better... :wut:
Still need to tune the carbs and set both of them the same...
^^ finally got out the ole hammer and bit of wood and fixed this up so i could bolt this back on looks better already...
once cars running... ill be getting that rear ding fixed among other bits of the body :thumpsup:
geezer101
Post by geezer101 »
It's coming together nicely. The twin carbs are nice and clean, so hoping they're already set up. Looks like you've got a decent exhaust too. Soooo close to getting it sorted- looking forward to the post where it's "turn the key and go!" :D
GC75
Post by GC75 »
will test everything today, fingers crossed. :thumpsup:
There is no fingers crossed icon so I choose this one instead :mrgreen:
GC75
Post by GC75 »
carbs need adjusting.... fuarkkkk i suck at this... need halp!
geezer101
Post by geezer101 »
No help to you here! I couldn't even figure out how to post pics for a while. :ban: I never got the chance to mount up my set on a running engine- mine are garage ornaments... D'oh! :$
ISKA8
Post by ISKA8 »
what happened there buds?
MY NEW TOY F6310
geezer101 wrote:No help to you here! I couldn't even figure out how to post pics for a while. :ban: I never got the chance to mount up my set on a running engine- mine are garage ornaments... D'oh! :$
Do these ornaments have a manifold? If they did, would this manifold be for sale?
GC75
Post by GC75 »
ISKA8 wrote:what happened there buds?
Past owner i believe, i didn't mind though when i bought it... my galant was rusty and banged up as haha, and ive got a quote for fix thats fairly reasonable.
FATGSR
Post by FATGSR »
Yes past owner not me lol... i bought it like that myself lol...
Wat a little grunter that is..
would so of blown tha doors of that Sig wagon i just Passed on.. lol...
"If YoU CaRnT SwInG It DoNt BrinG It" "LoCk It &StOcK It"
GC75
Post by GC75 »
haha fine past past owner.
only body repairs needed doing are:
Drivers door (rust)
Rear end
and a bit of rust in the boot seal.
other then that been over it completely... all pretty neat and today i attacked the car with fish oil.
Also bought a new fuel pump, mounted it in the boot... Just gotta wire everything up now.
Also going to re-do engine wiring again, not happy with it... want everything neat and so i understand what everything is doing...
also going to mount some brake lights on the rear shelf... should look pretty sweet when i do it all, shall have it done tmoz.
also going to hide all wires in the tube stuff with the split in it, looks heaps tidier.
After its all back on the road, going to get the body straight and all rust cut. :thumpsup:
NNNOOOOOOOO, don't put brake lights on the parcel shelf :hit: They look effen stoopid IMHO :@
75wagon
Post by 75wagon »
^^^ I'm with Jason on this one... ^^^
GC75
Post by GC75 »
i rekon they look cool so im gunna try it haha.
I reckon your shit!
GC75
Post by GC75 »
nehhhh
geezer101
Post by geezer101 »
If it stops some 'tard from arse ending you, go for it. One of those L.E.D. bars in a tube will get their attention! 8-)
FATGSR
Post by FATGSR »
Im with jason.... GAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY
GC75
Post by GC75 »
geezer101 wrote:If it stops some 'tard from arse ending you, go for it. One of those L.E.D. bars in a tube will get their attention! 8-)
haha ay, well might save the car from looking like it does now again!
and i rekon it will look good with rear venetions, forgot to mention that. haha
geezer101
Post by geezer101 »
You'd have to really twist my arm- got the full set up with new brass linkages port matched to a head. Wouldn't really be prepared to separate them...
Locked
