TUFSIG, GK Sigma GSR 2.6 EFI Turbo
natosig
Re: TUFSIG, GK GSR 2.6 EFI Turbo - NEW UPDATES
Post by natosig »
Mate that is an awsome effort you've put in to this sigma it looks absolutely awsome
84 gk sigma
TUFSIG
Post by TUFSIG »
Update
Got the turbo back with a double seal on the rear and now have a oil pressure reg and no oil out the back of the turbo now so all good, now i can finally get it too to get new 3inch system and new ecu with coil per cyl setup as well
TUFSIG
Boost Is the Only Way
1984 GK Sigma GSR Stocka
TUFSIG
Post by TUFSIG »
Towing TUFSIG to the exhaust place to get new system fitted, Monaro styles
TUFSIG
TUFSIG
Post by TUFSIG »
Battery mounted and connected up, just finishing touches now for the car its running mad now that i fixed the timing
TUFSIG
TUFSIG
Post by TUFSIG »
As cars go i have another issue now the oil pressure is way too high sitting at 70psi at idle so ill have to take it off and check it out more then likely new oil pump is in order
TUFSIG
Billsy
Post by Billsy »
is that cold idle or up to temp idle?
what viscosity oil is in there?
70psi isnt too high. what does it go to when revved?
I even shimmed my oil pump when i built mine for higher pressure than std
TUFSIG
Post by TUFSIG »
thats just fresh cold oil it sits around 60psi and once warm around 70 and then goes up under aceleration and the oil is going past the turbo even with a double ring in it, been doing some reading and at idle i should be around 30psi or so and max 60psi. Garret also said no more then 60psi is needed in the turbo as well,
i already have a restrircter on the turbo oil line but im thinking i will have to setup a reg to ease the pressure till i get the pump looked at.
But from all indications 70psi at 1000rpm is not right at all hence why i believe the turbo was having the oil blast past the seal and then even go past it after a fresh rebuild.
TUFSIG
Billsy
Post by Billsy »
what viscosity is the oil?
TUFSIG
Post by TUFSIG »
Hey People
I have entered my 3000gt in just car rate my ride thing, If you have facebook and want to vote for me here is the link :P
https://www.facebook.com/justcar/130076 ... pp_data=85
TUFSIG
TUFSIG
Post by TUFSIG »
Car is running but still not 100% i hate fuel only ECU junk, i was looking at updating with a newer microtech but after speaking to engineer i will need a computer with a closed loop so it looks like Haltech will have to be the goer atm
Some New Pics
New Gauges at night
TUFSIG
TUFSIG
Post by TUFSIG »
First wash in 3 years so all nice and clean now, cant wait to get new ECU and stainless system, the current exhaust makes it sound like a V6 commodore and this is just not right :P
TUFSIG
81GH
Post by 81GH »
gauges look rad, love how the lights match the stereo illumination :)
85GK GSR - EFI Camn
85AB GSR VR4dia- Build
TUFSIG
Post by TUFSIG »
Cheers mate, Getting another muffler put on this Sat cause its way too loud and the drone is so annoying
TUFSIG
ISKA8
Post by ISKA8 »
hey ya doing mate,nice too see you finally finished this beast..been a long ride but well worth it...looking good!
MY NEW TOY F6310
TUFSIG
Post by TUFSIG »
Cheers mate, still a while to go yet till its running all good but its driving at least
TUFSIG
TUFSIG
Post by TUFSIG »
Decided to actually paint the cooler because the other one stuck out like dogs balls through the front grille
TUFSIG
Benharjon
Post by Benharjon »
Very stealth! Great work :thumpsup:
Cheers Ben
TUFSIG
Post by TUFSIG »
Cheers Mate
Had the turbo exhaust gasket blow out on me last night so lucky i had a new metal one on order
TUFSIG
lol, there is always something.
I like the stealth look, a big shiney FMIC really is for VL Commodores :P
TUFSIG
Post by TUFSIG »
god i hate VL Turbos lol
TUFSIG
TUFSIG
Post by TUFSIG »
I was looking at the SR20DET gh on ebay as a drift/track car though
TUFSIG
FMIC????????
F**king massive intercooler c**t???
TUFSIG
Post by TUFSIG »
Only a 400x300 so not too big, you can fit one to a GK with no cutting at all which is good as well, or you can fit a 600x300 if you want to hang it out the front like a hectic VL turbo
TUFSIG
Benharjon
Post by Benharjon »
Good choice on yours! Stupid Vl guys...
Stealth all the way! (H)
Cheers Ben
TUFSIG
Post by TUFSIG »
I can make it as stealth as i want but i think the plates will always give a hint of something
TUFSIG
TUFSIG
Post by TUFSIG »
Now to be the ECU for TUFSIG, Haltech Sprint 500
TUFSIG
(H)
TUFSIG
Post by TUFSIG »
No more shitty Microtech :P
TUFSIG
TUFSIG
Post by TUFSIG »
Turbo gasket finally arrived from the states, no more blowing out gasket, this shit is genuine lol
TUFSIG
turbogj260
Post by turbogj260 »
get more ponies with that ECU. Microtech = Megga shit...
81 Turbo GJ SIG-260
04 BA GT BA GT
