Mick's LA75 Lancer
regina
Mick's LA75 Lancer
Post by regina »
Originaly bought in 2000 from a little old lady who bought this car new from show room. Names after the street she was bought from, Regina.
Starion block with VR4 4G63 head.
1mm oversized forged pistons (Weisco)
Nitrated & Crack tested Starion Crank shaft
Shot penned Starion rods
Balanced internals with balance shafts removed
Metal three layer head gasket
Autronic SMC Computer
M&W CDI Ignition
Davies Craig water pump
Intercooler with custom tanks
Custom oil cooler
Custom oil catch can
Custom overflow tank
Custom Crank and Cam angle sensor mounts
2x Coil packs
‘Cyclone’ modified plenum
Vr4 inlet manifold
GT28RS Turbo with Custom Steam pipe exhaust manifold
3 inch mandrel custom exhuast to the rear.
Nissan 280zx Independant Rear Suspension cradle installed
Custom rear shock towers and bracing
Rear Coilover suspension - Front GH Sigma struts with coilover setup KPS-103 Front Springs, Free Height 180mm, Inside Diameter 65mm, Rate 250lbs/In, Solid Height 80mm. Tender coils, K65S, Free height 70mm, Inside Diameter 65mm, Rate 70lbs/In, Solid Height 15mm. FH-5020 Tender Spring Spacer (65mm I.D coils).
Front coilover suspension
Custom KE70 Rack n Pinion setup.
Toyo Proxes T1R 195/50
Mazda RX7 calipers with FD rotors.
Mick Carmody
http://reginala75.wordpress.com/
1975 LA Lancer - 4g63 - 1.13.8 Wakefield Raceway
Skidmark
Re: Mick's LA75 Lancer
Post by Skidmark »
sounds awsome ,love to see some pics .
85 GN ,daily driver
86 GN ,resto project .
I am affraid I am going to need more info and pics on the IRS, all pics in general will be needed, lol
Wow, you've done some work to this.
Not showing pics is a tease.
kirkstanton
Post by kirkstanton »
:O my jaw literally dropped as i was reading that list, we seriously need to see some pics! it sounds insaneee
dvsfin
Post by dvsfin »
is this the blue lancer that had the back seats removed...with a cage and everything..?
Looks like a black Lancer to me, matches perfectly with the back ground................................... we NEED PICS :(
81GL
Post by 81GL »
You youngsters :)
Absolutely love this car too...
Hope you don't mind me putting the link here Regina?
http://www.sigma-galant.com/archive/mod ... 17&start=0
Nick.
dvsfin
Post by dvsfin »
oh i remember this 1...i just thought it was a different mick with an la who i bought some extractors off a couple of years ago :P
regina
Post by regina »
Haha, yeah cheers, wasn't sure whether to re post everything or just start fresh.
Mick Carmody
regina
Post by regina »
Cob Webs blown off
Mick Carmody
stealth
Post by stealth »
mate it been a long time between post but welocme back
have you finished her now and is it all sorted
last i heard you were getting it dynoed just after getting it going
cheers stealth (H)
DanTurboLancer
Post by DanTurboLancer »
Mick what a weapon, puts pics up Please!!
regina
Post by regina »
Unfortunately she's been on hold for a few years. Houses, weddings ect... they take their toll. Hoping to get back into it this year though. Its all about priorities, right guys?
Mick Carmody
DanTurboLancer
Priorities???
Marriage :banh:
astronturbo77
Post by astronturbo77 »
i remember this car from the old site. welcome back. loved the irs conversion. Pics pics pics pics pics pics pleeeaaasssee :wank: :wank:
regina
Post by regina »
Wakefield 2007
Mick Carmody
regina
Fix few niggling problems
Post by regina »
Decided to fix a few niggling problems leading up to Wakefield. Have never been to happy with the location of the water pump. Not only did it look ugly but also made a hell of a racket when the pipes hit the car. Also found the annoying exhaust leek. Two bolts snapped out of five, attaching the turbo to the dump pipe.
Engine out
Old water return line
Location to fit water pump
Mick Carmody
The AuStarion has a section on the twincam conversion along with a front mount thermostat that eliminates the need for the rear water pipe.
The only other thing I would do is to put a restrictor on the front water ports leading to the head (near the cam gears) to make sure the rear of the head gets enough water flow.
I will try and find the info if you are interested.
regina
Post by regina »
Howdy all,
Thinking about getting rid of this car and just after some opinions on pricing? Has been garaged for some time and I just dont seem to get much use out of it any more. Required rockercover gasket and one brake line for it to be running. Of course it has run out of rego, so if you want it on the road will need engineering. Thinking of putting the money towards a triton or similar. Lots of spares ect to go with it also.
Cheers,
Mick Carmody
regina
Memories
Post by regina »
Ah the memories...
Mick Carmody
yno26galant
Post by yno26galant »
Might be intrested in buying.
