100mm is all I need. The standard cable just can't reach.
Ooops forgot, I'll see what I can do?81GL wrote:Got some pictures of the finished(/ repaired) product
All I've actually done to the car was add the wheels, the previous owner did the rest.James wrote:So yeah, just dropped in to say hi, great work on the car, eat a bag of dicks, it looks good in orange and white and I hope you get some good times out of it if you ever get to take it to the track.
I appologise if my driving offended you, that was not my intention. The right lane was clear (and there was another 3 cars lined up behind you), and I intended to pass the Mirage in front of you as well, but decided to slow down a bit. I did not realise you had not seen me beside you until you blew your horn. Even my passenger asked what you thought I had done wrong?James wrote:Well, when I've run out of lane and you've come up from behind and are still level with the side of my car (I could hear you accelerating and I had to brake pretty hard BTW) don't forget to give the bullbar a pat as it says hello through the passenger window.
Depending on how long ago, you may have been on the old site? Everyone had to rejoin up to this one when it was redone.James wrote:I'm actually an old member of here from God only knows when, but my old login must have been purged as it's been ages since I was here.
It's got a belt drive fitted.James wrote:Someone must have fitted the chain drive motor as the LC were all belt drive from factory. Not a bad thing as the chain drive motor is a much better motor.
