Small problem...
webby
Small problem...
Post by webby »
Car starts fine when I short the starter, but when I go to start it on the key I get nothing. Dash lights all work, it just won't turn over.
Ideas?
Re: Small problem...
Fuse, or fusable link?
Slip on wire fell off or loose on starter motor?
webby
Post by webby »
Fuses are fine, starter wiring is attached/secure.
NFI on fusible links, as I'm not sure which one's which. They all look fine though?
It's pretty weird, as it was working fine a couple weeks ago :\
GB_BB4C
Post by GB_BB4C »
dodgy ignition switch, wire unsoldered itself from back of ignition switch, dodgy inhibitor switch (if auto).
webby
Post by webby »
Inhibitor switch
:facepalm:
Forgot that was still in there :lol:
That could well be the issue, as I use it as a killswitch. It's kinda a necessity when you've had three driver's windows snapped off so the local kids can steal your smokes/try and steal the car :facepalm:
Cheers guys, carry on :$
Check the wire going to the solenoid is still attached.
Have had this problem several times..
