wiring up 4g32 electronic dizzy
shuggy
Post by shuggy »
so i have aquired an electronic dizzy for my 4g32 with 4g54 dizzy guts..
do i have to use the sigma control unit or can i get a betterone to suit witout moving onto micro computer control ignition..??
colta51
Contact:
Re: wiring up 4g32 electronic dizzy
Post by colta51 »
sure its 4g54 guts? it cood be nimbus 32b or 4g37?
shuggy
Post by shuggy »
no idea, but it looks identical to the one in the siggy manual
oldn64
Oldn Engineering
Post by oldn64 »
Post a pic up of the internals shuggy, if it is what I am thinking of then it is inductor type and you should be able to use a standard Sigma/magna Bocsh ignition module where you mount it to the dizzy or run the two wires from the dizzy to the module then from module to the coil.
Pic will help.
The way God intended it.....Chrysler for the win :D
shuggy
Post by shuggy »
oldn64
Oldn Engineering
Post by oldn64 »
Righto,
this is hall effect so will not work with the later module, you will need the GE/H module that is on the passenger inner gaurd, failing that look in a early nimbus. wire it up should be all good to go.
shuggy
Post by shuggy »
cheers mate, the GE in my back yard had a 2L il see if it has one..
thanks a lot
krohny
Post by krohny »
you need one of these set ups shuggy..
shuggy
Post by shuggy »
isnt that basically what ive got?
whats the dif?
krohny
Post by krohny »
yeah, mine has the module inside it though.. just a newer design i believe, and i found a transistor ignitor that gives maximum spark at all times, plus its a GT40RT race coil..
