Hey guys im just in the process of wiring up An EMS 4424 to my TR magna Wiring loom and was just wondering if someone can shed some light on what i would do to wire up my magna TPS which has 4 pins im assuming that it has a Signal(full range) and Signal(narrow range) and thats why theres 4 pins. i have tested and found the 5v and ground wires but the EMS wiring diagram only shows 3 wires going into the TPS it only shows one Signal wire.
Just wonder what i am supposed to do here? do i go and by a TPS with just the single signal output or can i do something with the magna one?
this is my first time at doing a job like this so be gentle
Thanks
Peter
Throttle Position sensor
Re: Throttle Position sensor
I took a shot of a blokes car that had it done If I find I will post up...
hey thanks man
Is this guy a member of the Sig/gal forums?
if so do you have his username so i can have a chat and see whats what? because the photo isnt quite enough help
thanks
Peter
thanks
Peter
