xf faclon idle motor?????
hi guys im using a xf throttle body on my efi 2.6, been told i need a xf falcon idle motor??? is this the correct term to describle it? anyone have one laying around? and how do i pulse it to get it to idle. im pretty sure it just creates a air lear between the plenum and berfore the throttle plate?
- DanTurboLancer
Re: xf faclon idle motor?????
How did you go with this mate?
Is it an Idle Motor,
Or idle up Solanoid??
Or an ISC "idle speed controller"DanTurboLancer wrote:Is it an Idle Motor,
The ISC and/or Idle motor are just stepper motors (either 4 or 6 pin connectors usually) that can finely adjust the idle airflow
but
the idle solenoid (2 pin connector) is either on or off
I know the EA Falcon's have a solenoid and I'd expect the XD's have the same.
the falcon idle control solenoid is a ON/OFF air bypass.
its not adjustable and cant be used with PWM ecus AFAIK.
ive got one on mine and it raises idle to around 2000rpm when warm, so i made a new gasket for it with a smaller hole in it which makes it manageable.
