!!!! Heater/fan blows fuse whenever used !!!!
In my 76 Galant whenever i try to use the fan/heater it blows the fuse and stops working (obviously).
an auto electrician looked at it and could find the problem.
if you guys have any idea on how this could be caused and/or how it could be fixed, would be extremely helpful.
Current
Nissan S15 Silvia Autech - stanced and low daily/drifter
Past
95 Honda Civic EG VTI - blew up
75 Chrysler Galant Sedan GC - :/
98 Subaru Liberty 2.5L RX AWD - old daily cruiser
91 Nissan Silvia S13 SR20DE - filthy drift pig that was a mistake to try have as a daily
76 Chrysler Galant Sedan GC - sadly missed ;(
Current
Past
Re: !!!! Heater/fan blows fuse whenever used !!!!
OK.
You have a straight short somewhere, you've just got to find it. It might be in the fan motor or in the wiring.
You need to systematically go through your wiring to find it.
Just reading your post again....
Does it blow the fuse straight away when you turn it on, or does it run for a while then blow the fuse.
Could it be leaves and shit that has made it down your vents and jamming the fan and therefore motor?
Could just be the motor is F--k'd.
yeh it usually runs for a minute or two then blows the fuse, it run for about a half hour trip once and sometimes it goes as soon as i start the engine
it's a bit weird
it's a bit weird
Current
Past
Current
Past
Most likely the electric motor is stuffed because:
1. The bearings are stuffed, not letting the armature spin freely.
2. There is some debris in the fan stopping it spinning .
3. The commutator's all clagged up causing a direct short across several of the windings.
4. Some of the windings have shorted together because the insulation has died.
Another few things to check would be the switch in the dash or the "wire resistors" in the fan box (used to control the speed). Either could possibly short to ground, causing the fuses to blow.
- 81GL
In that time that it is running, does the motor sound healthy?
Nick
Nick
the motor sounds fine to me, i'll check all the wiring when i get a great deal of time
thanks for your help
Current
Past
Current
Past
One more question.
Does it blow when you run it at full speed?
This could be it if it doesn't blow while on full speed, because the fan runs unresisted. So what I'm saying is it could be the switch....Superscan811 wrote:Another few things to check would be the switch in the dash or the "wire resistors" in the fan box (used to control the speed). Either could possibly short to ground, causing the fuses to blow.
it's blown at all speeds, i mostly use full speed
Current
Past
Current
Past
does tend to sound like you fan motor...
dam...where and how much can i get one?
Current
Past
Current
Past
I'll have a look I think I've got one....
Yeah got one, I'll bring it 2 moro. I'll have to take it out of the heater box and test it first though. If it works you can have it for $10?
cool, don't know if i need it yet but it's only $10 so it doesn't really matter.
thanks heaps man, it'll be good to get my fan going again for the up coming 45+ degrees summer ahead
Current
Past
Current
Past
All checked, works fine, sounds healthier then mine actually. But I've got it in my car ready to go.
See you at the cruise....
