Continuous +12v wiring.
mooey1232003
Post by mooey1232003 »
I'm wiring a head unit in a colt galant and was wondering if there is a +12v wiring from the fusebox i can use? Or should i connect it directly to the battery with an inline fuse in between.
Re: Continuous +12v wiring.
Look for the "Clock" circuit at the fuse panel.
mooey1232003
:D Thanks guy.
mooey1232003
There is no clock circut on the fuse panel.
It has:
Upper(R)
Upper(L)
Tail
Clearance
Wiper Washer
Heater V-Reg
Turn-Back
Lower(R)
Lower(L)
Hazard
Defogger Ant
Stop Horn
Parker Room
Cigar Radio
But can i connect it directly to the wires that the clock is connected to?
Get yourself a test light.
There will be constant positive, ignition positive and earth ( or neutral)
put the constant positive straight to the battery with a fuse.
put the ignition positive to a positive that onlt turns on with the ignition (hence the test light)
and the earth to the body.
Done.
mooey1232003
Thanks ill try that.
GB_BB4C
Post by GB_BB4C »
Hazzard and Stop/Horn should be 12v constant.
mooey1232003
Yip the wire from the clock is +12 constant. So I'm going to connect the head unit to there and have the head unit ignition wire connected to a switch. I'm just wondering if i need a fuse between the constant +12 from the clock to the head unit?
Yes you need a fuse.
You're better to run a wire for the constant straight to the battery, then you don't get interference or power drop when what ever else is on the circuit is running. eg if you hooked it too your wipers, or blinkers.
1978sigma
Post by 1978sigma »
i just connected it to the top of the fuse clip on the wiper washer fuse it is a 15 amp fuse so willl do the job just fine u just have to cut out a little v in the cover to fit the wire through
done this my self and has ben working fine since i instaled it
1978sigma
If you do this you are likely to get interference from the wiper circuit while driving in the rain.
That's why it's best to draw the positive straight from the battery. No interference or power drop.
