Fuel Gauge Issue
Posted: Thu Mar 19, 2015 5:35 pm
I am seeking some advice about my fuel gauge on an LB Lancer 4G32. Recently my alterantor failed and at the same time the fuel gauge stopped working. I have replaced the alternator with a new Ford one. All good. I droppedn the tank and tested the feul gauge and it was dead. I replaced it with another second hand one and it works outside the tank. I can move it to full and it is reflected on the dash almost full. It seem less sensitive down the lower end, but it works. When I put it in the tank i put in 30 ltrs and it didnt move the gauge. I filled the tank and the dash needle showed about half full.
How you I calibrate the tank senstor to that of the needle on the dash. Is there a resistor somewhere that could be faulty or need to be matched to the sender unit???
So many questions, but no answers. HELP anyone.
David
0433 740007
David
0433 740007
