Car only runs when key is turned half way
hengagc75
Post by hengagc75 »
What kind of problem do I have if the car only starts and runs if they key is turned halfway between on and start? Was told it could be ballast resistor but just wanted to see if anyone else has had any similar issues. It's not my car it's a car I'm wanting to buy but it's quite far away so I wanted to know what I'm dealing with before I go look at it..
Jordan1249
Re: Car only runs when key is turned half way
Post by Jordan1249 »
Sounds like ballast had exact same.problem
MadMuz
Post by MadMuz »
Could be a dodgy ignition switch?
geezer101
Post by geezer101 »
Would be my bet too. Sounds like the contacts in the switch barrel are shot...
MadMuz
Post by MadMuz »
Yeah, I had a dodgy ignition that when cranking, the ignition wire wasn't hot, until you stopped cranking..... pain in the butt. Check the power outputs on the ignition switch, or try another if you can get hold of one
