What does it take to convert single to dual headlights?
Postby hengagc75 » Mon Jul 14, 2014 10:21 pm
I am wanting to convert my gc from single to dual headlights and was just looking for any information people might be able to give to me to make the whole process smoother.. Any past experiences or obstacles you may have faced etc. and what exactly the whole conversion consists of, thanks!
hengagc75
Country: Australia (au)
Re: What does it take to convert single to dual headlights?
Postby LukeAussie » Tue Jul 15, 2014 4:25 pm
This should be a relatively easy conversion. You'd need to isolate the control (power) wires for the high-beams, and daisy chain these over to the two centre lights (for high-beam only operation), as well as the earth, and would obviously need the lamps, globes, globe connectors, etc. And then you'd need an appropriate grille too, and brackets to mount the lights. And that should be about it... you could always try to hijack parts of a GD too, to make your life easier :)
LukeAussie
Postby A112H » Tue Jul 15, 2014 7:23 pm
The headlight buckets in GC/D Galants are welded in, the hardest part of the conversion would finding twin headlight buckets and then they need to be neatly unpicking them and welding the twin buckets in.
I think I would just search the interwebs for a period pair of spot lights and fit those, IMHO.
If you make a bracket and mount to the number plate mount there is no need to cut or weld anything.
Postby hengagc75 » Tue Jul 15, 2014 7:34 pm
I know what you mean but i really like the look of the dual headlights on a gc. There's a gd at my wreckers with everything i need, think i will have to get a hacksaw onto those headlights buckets..
hengagc75
Postby geezer101 » Tue Jul 15, 2014 7:58 pm
You'll need to drill out the spot welds on the headlight bucket mounts. Then there's the extraneous wiring.
Postby A112H » Tue Jul 15, 2014 8:07 pm
Hacksaw wont cut it, well it will 'cut it' but not in a reusable way.
As mentioned, you will need to drill out the spots or with a fine disc on a cut off saw you could carefully cut it away from the rad support
Postby hengagc75 » Tue Jul 15, 2014 8:18 pm
Guess I'm gonna have to figure out a way to get power tools into the wreckers :\
hengagc75
Postby A112H » Tue Jul 15, 2014 8:27 pm
Cordless :thumpsup:
Postby hengagc75 » Tue Jul 15, 2014 8:30 pm
Haha I think I might have to.. Do you know if I will have to use the gd bar aswell for the park lights?
hengagc75
Postby A112H » Tue Jul 15, 2014 8:37 pm
Depends what lights you run or the look you want.
If you convert the lights to new ones taking H1 globes most come with a hole and plug for a parker.
http://www.ebay.com.au/itm/CRYSTAL-VISI ... c10&_uhb=1
Or you can run the JDM front apron like mine with the lights in it.
Postby A112H » Tue Jul 15, 2014 8:44 pm
**H4 Globes**
Where has the edit button gone??
Another improvement I guess, LMFAO
Postby hengagc75 » Tue Jul 15, 2014 11:32 pm
I like the jdm look, are those lights from the new colts?
hengagc75
Postby LukeAussie » Wed Jul 16, 2014 9:26 am
With the parkers, you have a couple of options including keeping the standard GC ones (having a combination of the GC and GD look), or completely changing to GD ones (I have a GD bumper with the parkers down there, but normal GC single headlamps).
Good luck with it all!
LukeAussie
Return to Electrical/Audio
Who is online
