GA Galant Lights - Compatibility with other models
gaPhil
Post by gaPhil »
I've heard a rumour that the headlights from GA galants are the same as a model of the ford bronco or f250? in the states.
Can anyone confirm this is correct? Or any other car.
Upon searching the net, the only common square headlight i can find is a 7"x6" light. The GA head light seems to be wider than this.
I know they are are Stanley type light. There are some sort of model numbers on the back of the light but i cannot read it on my set. Is anyone able to read it on theirs?
It would be great if we could find aftermarket lights that fit, i really dont want to convert to the GB front!
71 GA Galant - Project
Build thread is here: http://www.sigma-galant.com/viewtopic.php?f=48&t=5600
gaz914
Re: GA Galant Lights - Compatibility with other models
Post by gaz914 »
Back in the 80's, a bloke told me that TD Cortina headlamps could be made to fit.
Unfortunately, they are probably like rocking horse shite now as well :(
I haven't found anything either - although I don't need them to work on the khana car!
Gaz
The headlight issue pops up a lot when you're talking about the GA galant. I think you'll find there are no direct replacement/fitment headlight assemblies for the GA, so ages ago I ran a thread on modifying the GA headlight into a H4 halogen assembly. The example I converted was off a Honda Elite scooter but the method is the same - http://www.sigma-galant.com/viewtopic.p ... ght#p64062 Obviously no good if the headlight is smashed but if you find a dead one at least you can return it to service...
davetrees
Post by davetrees »
Have you tried Mk1 Escort headlights ? Dunno about dimensions, but they are a small rectangular light.
(although personally I don't know why anyone would want to keep the crappy stock GA headlights ..... :P )
davetrees wrote:(although personally I don't know why anyone would want to keep the crappy stock GA headlights ..... )
This is why he's asking the question. He wants to keep the appearance, but doesn't want to be the 'Lord of the Darkness' anymore.
Can anyone confirm the the F150 lights will fit? New lights with the H4 set up, is just what Phil is after.
These are 190mm x 130mm
http://www.ebay.com.au/itm/Ford-F100-F1 ... 921wt_1037
These are 185mm x 130mm
http://www.ebay.com.au/itm/Hilux-Rodeo- ... 504wt_1271
I am very surprised they are different from L200, Triton and Lancer. It is very un-like Mitsubishi to change them for one model. Anyway, I am sure there would be a company in NZ making aftermarket headlights for them. Have you tried our NZ members or asking on the various FB pages??
Interesting :think:
Those F100 lights have curved sides (just a bit)
The GA's are dead rectangular 4 perfectly straight sides.
GB_BB4C
Post by GB_BB4C »
as far as I know there is nothing the same as the GA Galant headlight's. I have inquired about getting a set of mine done to take the H4's. they would pull it apart, fit the bracket in for the H4 then re-chrome it and glue the glass back on. the only thing is how well the glass is stuck on in the first place as to weather it would be broken upon trying to remove it. which in that case you'd be up shit creek... I cannot remember how much it was going to be to get done.
here is their website, they are located in SA
http://www.classicandvintagebulbs.com/
That is the long and expensive way to mod a headlight to a H4 assembly (not to mention risky). The glass is held onto the backing case with some serious epoxy resin! It would require a steady hand and a mini grinder wheel to cut into the epoxy to the point where you might be able to pry the glass free. It might be worth having a locator hole cut into the backing case to allow the fitment of a parking light... After some fresh chroming and some good H4 globes they will be killer headlights (H)
davetrees
Post by davetrees »
If you can find a rectangular halogen light that is close in size (if not exact) then if you mount it carefully then no one would ever notice anyway.
This guy found the best and most attractive option for GA Galant headlights, lol
gaPhil
Post by gaPhil »
Madness! Square lights suit the square styling of the car..
GB_BB4C
Post by GB_BB4C »
geezer101 wrote:That is the long and expensive way to mod a headlight to a H4 assembly (not to mention risky). The glass is held onto the backing case with some serious epoxy resin! It would require a steady hand and a mini grinder wheel to cut into the epoxy to the point where you might be able to pry the glass free. It might be worth having a locator hole cut into the backing case to allow the fitment of a parking light... After some fresh chroming and some good H4 globes they will be killer headlights (H)
they actually heat the surrounding up with a hot air gun to soften the glue, that usually gives enough to be able to pry the glass off. depending on what has happened to the glass before and how well the glue is still holding the glass on depends on weather they crack it or not.
gaPhil wrote:Madness! Square lights suit the square styling of the car..
:P :lol:
GB_BB4C
Post by GB_BB4C »
gaPhil wrote:I know they are are Stanley type light. There are some sort of model numbers on the back of the light but i cannot read it on my set. Is anyone able to read it on theirs?
front:
Stanley Sealed Lamp Japan (etched into the glass)
Rear: written on the back of lamp
R (right lamp, L on left)
6.1661
Stanley
60/45W
AA21 (cannot see/read on any of my other lamp's)
What is the model number for a GA ??
A112H wrote:This guy found the best and most attractive option for GA Galant headlights, lol
That's a GB you tool.
Note: GB's have parking lights in the front beaver panel. GA's are parking light free.
GB_BB4C
Post by GB_BB4C »
75wagon wrote:Note: GB's have parking lights in the front beaver panel. GA's are parking light free.
GA's have the parker light's in the indicators.
GB_BB4C wrote:GA's have the parker light's in the indicators.
Sorry, I meant in the front beaver panel...
The comment was meant for twin headlight loving A112H... :lol:
GB_BB4C
Post by GB_BB4C »
all good, was mainly just clarifying for anyone reading etc.
I will admit I do like the GA front, but the standard light's (light output wise) are just shit to say the least. the standard sealed GB light's light up better than the GA's do. I just drove around with the high beam's on when I was running the GA stuff.
How far off would VH Valiant lights be? Mike you must have some around the place.
http://www.ebay.com.au/itm/VALIANT-RECT ... 6e6&_uhb=1
Nope, those aren't going to work. The GA headlights are bigger and are perfectly rectangular in shape.
What about Corolla KE70 rectangular lights?
No good either, too small.
gaPhil
Post by gaPhil »
Ke70 headlight dimensions.
I need to check but it looks about right.
GB_BB4C
Post by GB_BB4C »
the GA lights are
Overall
240mm/9.5inch X 150mm/6inch
Glass (raised section)
225mm/8.75inch X 140mm/5.5inch
geezer101 wrote:No good either, too small.
Your thinking about the one in the grill, like this;
I am thinking the flat face model, like this;
Remember there were at least 5 different faces for the KE70 (4th Gen) in its short life, lol.
GB_BB4C wrote:the GA lights are
Overall
Looks like they should be close GB_BB4C??
skap
Post by skap »
sealed beam would do?
These would have to be close, if one of our Asian members could measure one up for us (H)
Bullitt77
Post by Bullitt77 »
I'm looking for the blinker/parklight left side and bumper for a sigma 1977 .... can someone help me??
excuse me if I'm wrong site....
