Help - Durable paint options
Postby shuggy » Wed Oct 30, 2013 5:42 am
Hey guys.
My paint job that im doing is going to be a tricky one, but im chasing some help with it.
The question is, What is the best paint that is super heavy duty and durable, when aesthetic dont matter? It doesnt have to look good!
I have begun sanding back and repairing the car, and i have laid down etch and primer over the majority of the car now so im looking for the next step.
Im going to use one of the 3 following paint effects - Im steering toward copper
Zinc - http://www.porterspaints.com.au/paints/ ... iquid-zinc
Rust - http://www.porterspaints.com.au/paints/ ... stant-rust
Copper Oxide - http://www.porterspaints.com.au/paints/ ... tina-green
Thoughts?
shuggy
Country: Downunder (AU)
Re: Help - Durable paint options
Postby ozdusterdave » Wed Oct 30, 2013 7:44 am
Paint it the colour that you want it!
ozdusterdave
Country: Australia (au)
Postby shuggy » Wed Oct 30, 2013 1:39 pm
I'm asking advice on what to lay under it
shuggy
Postby bruggz351 » Wed Oct 30, 2013 3:16 pm
Thats house paint. Isn't there an automotive equivalent??
But, to answer your question, I like the idea of the copper and green patina....
bruggz351
Postby ddt » Thu Oct 31, 2013 9:16 am
Shuggy wants a heavy duty paint for underneath the effect paint so that the panels are well protected. The effect paint will be put over the top.
I don't know very much about paints so I dunno :think:
But I guess you want a paint with low porosity like enamel or something? Or what about having a clear coat in the middle?
ddt
Postby bumpy » Sat Nov 02, 2013 10:21 am
Not to sure what effect you trying to go for, but for me, etch repairs, and prime the whole car, and paint and clear, should be more than enough, but like i said, not sure of the effect your after. The copper oxide colour on the link reminds me of the rat rod look.
bumpy
Postby C_Fernance » Sat Nov 02, 2013 10:32 am
I've used POR15 in the past. I'd recommend it highly. It's not UV stable and will fade over time, but in a use like this where it is there to protect the metal and be painted over it would be perfect.
KBS Rustseal is an Australian made version that is supposed to work just as good, and cheaper, however I haven't had the chance to try it personally.
C_Fernance
Postby bruggz351 » Sat Nov 02, 2013 11:03 am
Keep in mind, that what you use, doesn't make any future repairs any more difficult than they have to be.
ie. if you use a very tough coating, it will be hard to sand and feather back for an effective repair.
Just a thought...
bruggz351
Postby shuggy » Sat Nov 02, 2013 1:28 pm
I've used KBS. Amazing stuff. But hard to paint over because its so hard to sand. if I just do a few coats of an industrial enamel that should be ok right? Not uv stable though right? Only thing in worried about is will the top Coat stick to it?
shuggy
Postby 75glnt » Sun Nov 03, 2013 12:18 am
Machinery enamel :)
And as long as the rest is enamel. It should stick. You can't put acrylic on top of enamel... But you can put enamel on acrylic.
75glnt
Postby shuggy » Sun Nov 03, 2013 3:01 am
Sanded back my boot lid today that was green metalic and clear coat, but didn't sand all the way back, just roughed it up, reckon should be okay? Primer seemed to stick
shuggy
Postby ozdusterdave » Sun Nov 03, 2013 12:28 pm
:facepalm: ^^^^ just do it
ozdusterdave
Postby Gormzz » Mon Nov 25, 2013 10:25 pm
Essentially i prefer to sand all the clear off a "clear over base" sprayjob. Doesn't necessarily need to go back to primer or metal otherwise i would just paintstrip it all. Simply once you have repaired what you wanted to.. etch prime, then lay down a proper primer surfacer or high fill primer (i use high fill). Now as already mentioned.. if you really want to be thorough with your work then yes a rust proof such as POR15 or some sort of rust proof can be laid on the panel prior/before the primer surfacer/high fill gets laid (Can get rust proof from most paint shops or autobarn/supercheap). Then its simply sand down with 400+ till desired smoothness and lay your top coat and then clear it. That to me has been the most durable way of painting and seems to last plenty of time. Also for a longer laster panel.. add at least 3+ coats of clear to fight against those uv sun rays. End of the day it does come down to the preparation work with the repairs and getting them sealed up again before salty air or such can reach it.
Toyota Cressida 77,79'
My projects/cars.
Gormzz
Return to Panel/Paint Shop
Who is online
