lower control arms
krohny
lower control arms
Post by krohny »
i know its been covered (too a degree) already but i just want a definitive parts list on what i need to buy to swap sigma lower control arms into my LB lancer.
a parts list and what model sigma they are all out of would be ideal
cheers..
astronturbo77
Re: lower control arms
Post by astronturbo77 »
as far as i know sigma gh ge lca's are the same length as lancer ones... why do you want the extra lenght?
krohny
Post by krohny »
i think i have gk ones..
its for negative camber for a rally car.. still not sure if its gonna be too much camber though
krohny
Post by krohny »
Still not 100% sure on this.. Anyone know?
gaz914
Post by gaz914 »
Use GJ on lower control arms plus the bolt that attaches it to the crossmember (ie the pivot bolt).
The Sigma LCA has a bush with a smaller hole in it than the Lancer one.
Cut off the Lancer "pivot bolt" (that went through the bush in the LCA) from the retaining plate.
Drill a hole the centre of the plate the same diameter as the Sigma pivot bolt.
Use the Sigma ball joints but use the Lancer steering arms/lower strut mounts.
Refit the retaining plate to the crossmember.
Insert LCA and fit Sigma pivot bolt (from the rear) and fit nut (don't tighten).
Connect strut, radius rod, etc.
Let car down onto wheels THEN tighten the nut on the pivot bolt.
Gaz
krohny
Post by krohny »
Thankyou muchly!
Rally_2.6LC
Post by Rally_2.6LC »
I wanted longer LCA too, I used Starion LCA, bush and ball joint onto my GH struts.
Sway bar and radius rod line up and gave me an extra 1.5-2 inch on the lancer ones.
I will say this though......the car has not run yet, test day is on Sunday at a motorkhana....its the entire car test day lol.
Will let you know how it goes.
Matt
krohny
Post by krohny »
i ended up just getting adjustable strut top mounts, seemed the easier option..
Rally_2.6LC
Awesome...where did you get those from?
When I put my LC on the ground it is now running some serious neg camber (bit much for tally, probably around 2.5-3 degree at a guess) so looking for strut tops to bring them back a little.
Cheers Matt
Pre-Evo
Post by Pre-Evo »
i've got K-mac strut tops in my LC running GK struts and LCA. Camber and caster adjustable. (H)
'79 LC Lancer injected 2.6 (project)
'00 Subaru Liberty RX2.5 (daily)
krohny
Post by krohny »
I just got universal ones off eBay, they were $100.. The k-Mac ones were $600 ha ha
Rally_2.6LC
Just FYI, the starion LCA gave me 2.8 degrees and 3.2 degrees neg camber (driver, passenger)
Wouldnt mind a link to those generic ones you bought as I want to turn mine back to around 2 degrees
Cheers Matt
krohny
Post by krohny »
I can't find a link on eBay to give you sorry, I just searched for universal strut or camber tops..
$100 Universal Camber Adjustment Plates on Ebay.
A bit of work involved to fit them, and the shipping on 1 item is $40 (but only $6 for each additional set).
Have seen the use of a pair of thrust bearings to greatly increase the life of the pillow ball in the strut tops. Again, a fair bit of work required but not particularly difficult.
I'd at least look at using a high density nylon bush to help (a little) with the sudden high shock loads.
krohny
Post by krohny »
They are the ones I got.. Cheers!
I haven't fitted them yet..
bundo
Post by bundo »
I am going through this conversion now.
The arms are about 4cm conger. Change the inner bushes with the new super pro ones but leave the centre steel sleeve out. Then the lancer pins fit.
I am using sigma struts so I am keeping the sigma steering arms on.
But I have a question, the sigma steering arms seem to be offset to take away negative camber, so are there sigma steering arms that are not offset? I am looking for as much negative as I can.
I hope to have the car back on the ground today.
simon
Post by simon »
it is some time since I did mine, I think you put the center sleeve in the bush and use a GH or GE bolt. there are a few different strut bottoms/steering arms. I think they are numbered 1 to 5 with an L or R
simon
bundo
Post by bundo »
