lb hatch spongey brakes
Hi wondering is this the norm or do i need to have a closer look at my brakes. The brakes work quite well but require a bit of a pump to come on hard, the fluid level is fine, and with about half a pump extrathey on well, but if you just apply gentle pressure and don't pump it the pedal will go quite far before you get a response. Is this the norm? If not any suggestions?
- BlueThunder
Re: lb hatch spongey brakes
Doesn't sound normal to me. Maybe there is air or water in the system? You could try to bleed the brakes or change the brake fluid? I don't know when you last changed the brake fluid?jameslikesstuff wrote:Hi wondering is this the norm or do i need to have a closer look at my brakes. The brakes work quite well but require a bit of a pump to come on hard, the fluid level is fine, and with about half a pump extrathey on well, but if you just apply gentle pressure and don't pump it the pedal will go quite far before you get a response. Is this the norm? If not any suggestions?
Have not bled the brakes yet, wanted to check what everyone thought before i get into it, if its regular then id leave it
Yep, bleed them james. Get a mate around to help you completely refresh the brake fluid while you're at it. Well worth the time and effort.
