Brake upgrade for GD galant
vr4galant
Re: Brake upgrade for GD galant
Post by vr4galant »
Found a brake kit that might suit the GD galant struts. Here the URL have a look.
http://www.wilwood.com/BrakeKits/BrakeK ... 40-11022-D
mic_77
Post by mic_77 »
Try it you never know until you try. I would use the sigma struts as it is tried and tested but each to there own.
Cheers Mic
vr4galant
Post by vr4galant »
I would if i could find the struts.. You know anyone who has some?
mic_77
Post by mic_77 »
Dapto pick a part has 2 GH sigmas if that is any help.
Cheers Mic
vr4galant
Post by vr4galant »
Gave them a call Mic they have a gh in and a few later models. Is the gh strut the only one that would work or will the later models be fine too?
Thanks for your help Mic i really appreciate it.
mic_77
Post by mic_77 »
They will work but can be a pain if they are 2bolt struts the gh bolt straight in who did you talk too at pick a part.
Cheers Mic
vr4galant
Post by vr4galant »
I spoke with Adam. He couldn't tell me if the struts were in there as he was the only one working. What simmons you running whats the offset on the rims? You got a photo with the simmons on?
mic_77
Post by mic_77 »
If I get a chance I will pop down there and have a look for you. I have 15x5 on the front with a 4in inner 1in outer.
Cheers Mic
vr4galant
Post by vr4galant »
looks nice Mic. What engine you putting in? That would be great if you could do that for me I'm planning to go down there on saturday morning.
mic_77
Post by mic_77 »
If they are still there I will try to pop them out and Adam will put them behind the counter for you.
Cheers Mic
vr4galant
Post by vr4galant »
That's alright Mic ill pop them out might need a few other bits and pieces. Just let us know if they are still in there.
Thanks Dude
mic_77
Post by mic_77 »
There is 2 gh's 1 sedan and 1 wagon both have struts in them.
Cheers Mic
amgis_obrut
Post by amgis_obrut »
Big brakes are simple on GH Sigma 2 bolt struts, you can use ANY big brake kit that's designed for a TE-F Cortina and they are a direct bolt on for GH Sigma struts !
Aren't the Cortina Discs still a Solid rotor??
amgis_obrut
TE and TF had vented discs but the factory brakes are horrible !
vr4galant
Post by vr4galant »
Thanks Mic your a champ.
mic_77
Post by mic_77 »
So your saying this kit will fit.http://m.ebay.com.au/itm?itemId=140923275031
Cheers Mic
amgis_obrut
That link takes my to the Ebay home page
If the kit is for a TE Cortina then yes it will fit
I run a TE big brake kit from Castlemaine rod shop on my GH, only thing I had to do was add some spacers between the calliper mount on the strut and the new calliper bracket
mic_77
Post by mic_77 »
The link should go to a UPC brake kit they have it listed for TC,TD,TE,TF for $899 good cheap way for a road legal kit much cheaper than hoppers.
Cheers Mic
vr4galant
Post by vr4galant »
Hey mic did you use spacers with your wilwood kit?
mic_77
Post by mic_77 »
I have a half inch spacer to stop the bolts in the Simmons hitting the calliper.
Cheers Mic
vr4galant
Post by vr4galant »
So those wilwood hubs are legal for street not the calipers?
Is your car for the street Mic?
mic_77
Post by mic_77 »
The engineer I spoke with on a couple of occasions is happy to engineer my car once I change a few things one of them being the callipers he said that the hub and disc setup is fine.
If you want it to be a street car I would look at the hoppers kit or if the te cortina fits look at the UPC kit they are better priced compared to hoppers.
Cheers Mic
amgis_obrut
I wouldn't mind getting a UPC kit so I could 100% confirm its a bolt up, I can 100% confirm that the CRS Cortina kit fits on the sigma 2 bolt struts, this allows you to use 298mm falcon discs and wb Holden callipers or VT commo callipers with some minor mods to the calliper bracket
Im pretty confident the UPC conversion would fit up the same as the CRS kit
The use of local callipers makes the hole conversion easy on a sigma as a 1" commo or falcon MC bolts up to the sigma booster !
vr4galant
Post by vr4galant »
Hey Mic got the struts off the sigma thanks for your help.
mic_77
Post by mic_77 »
No problem did Adam end up serving you?
Cheers Mic
vr4galant
Post by vr4galant »
yeah Adam served me good bloke? Time to upgrade my brakes
Andrew77
Post by Andrew77 »
Don't know if this helps,
I'm currently doing brake upgrade on GD Galant Rally Car:
Been using early scorpion Struts for a while now that have been converted to coilover (straight bolt up very simple). Currently with a bit of mucking around I am adapting, 4 pot Series 3 RX-7 4 pot calipers with Starion rotors. These calipers you can pick up pretty cheap and they are very light (Cast Aluminium construction) I got mine for $150 delivered from ebay in the US. I have had to hand make the brackets and spacers required and there is a little bit a machining required but I pretty confident it will all work.
Cheers,
Andrew
vr4galant
Post by vr4galant »
Hey Mic how did you centre your simmons with the hub. Are you using the lugs to centre the wheel because the wilwood hub centre is cone shaped you couldn't use it as a locater to centre the wheel perfectly so theres no vibration. A lot of wheels use the centre hub as a locater to centre the wheel perfectly. What have you done?
Thanks Steve
amgis_obrut
Wheel studs centre the wheel just as good as any hub, the centre hub does not support the wheel in any way (that's why some hubcentric rigs are plastic), its basically the friction between the wheel/hub combined with clamping from the fixings that hold the wheel in place
