skyline shock insert in gh struts..
Posted: Tue Oct 01, 2013 6:09 pm
by GLANT
Simple question, need to capture lowered springs in a gh strut, will the skyline/pintara struts do it? With only a spacer, either top or bottom.... to make shock secure in strut body? Also does skyline strut bolt to gh strut top?
Re: skyline shock insert in gh struts..
Posted: Tue Oct 01, 2013 6:10 pm
by Scorpma82
there is a thread in here regarding that same enquiry......tho it is quite an old topic......from memory its under the suspension category(one on the oldest threads there
that may help u out
Posted: Tue Oct 01, 2013 6:48 pm
by GLANT
Yeah lots of speculation, really want to know for definite.... engineer does not want cut and shut struts, and rwc wants captured spring.. I'm hoping someone has done it, and knows for sure it can be done.... I have to order shocks in and there is no return if they are not right.... just cant afford to mess up.
If only there where low shocks for a sigma available! But there are not...
I know they're shorter in body length, spacers are no prob, might do 20mm bottom and 20 top, but at this stage I really want solid proof they fit strut tubes and strut top.. as specs are impossible to find on the shockers.
Thanks mate for your input :-)
Posted: Tue Oct 01, 2013 7:04 pm
by Scorpma82
honestly....put the original stuff in the car....get ur paperwork signed....then do what u wanna do.....but i know what u mean by no definate answer
Posted: Tue Oct 01, 2013 7:57 pm
by mic_77
Shorten the strut tubes and use mr2 rear strut inserts.
Cheers Mic
Posted: Tue Oct 01, 2013 8:32 pm
by Scorpma82
wouldn't they be a bit soft????
Posted: Tue Oct 01, 2013 10:55 pm
by mic_77
It is what they use in the starions so can't see there being to much of a problem I have a set of KYB agx sitting here waiting to be fitted to my lancer just need to find the time to do it.
Cheers Mic
Posted: Tue Oct 01, 2013 11:02 pm
by Scorpma82
fair enough.....but if it's what they use in the starions.....y not just use starion struts???
or do u mean they use the same MR2 conversion in the Starion???
Posted: Wed Oct 02, 2013 8:50 am
by mic_77
Mr2 insert into starion strut do a search on austarion you will find what you need.
Cheers Mic
Posted: Wed Oct 02, 2013 8:25 pm
by astronturbo77
i used camira inserts on my race car, about 50mm was cut out of the shock tube.. whos gonna know its been cut if you put coil over sleeves over the weld? and theres no issues cutting aqnd shutting them if they are welded propperly
Posted: Thu Oct 03, 2013 3:46 pm
by Sigmaproject
I have Skyline/Pintara inserts in the Starion Struts on my wagon. But I cut about 40mm out of the strut tube, just below the thread. I used the GN Sigma strut tops and they bolt straight onto the Skyline inserts.
