Shorter strut inserts in GH Scorp struts...?
Hi all,
Simple question - which inserts do I use to capture GA Lovells Lows in GH Scorp struts? Lovells springs for GA is CFS-2; for the GH its CFS-3. I think the only difference is the poundage rate - the free height and spring outside diameter are the same as far as know. There's about 1 cm free play.
Ive heard that maybe Camira inserts with spacers under them or some model of Commodore inserts will do it, but Ive never actually heard from anyone who has done it.
Thanks in advance
Thanks in advance
John Ruskin
John Ruskin
Re: Shorter strut inserts in GH Scorp struts...?
sorry i posted then realised i misread your question
its going to effect your strut travel height but take out the inserts and get them shortened in a lathe (remachining the thread and step on the ram)
Commodore inserts drop into GH tubes, apparently ..... just need a small spacer (eg. a couple of 20c pieces) underneath.
- cheaterparts
the camira insert is quite a bit shorter in both over all lenth and body lenthtandanus wrote: Ive heard that maybe Camira inserts with spacers under them or some model of Commodore inserts will do it, but Ive never actually heard from anyone who has done it.
Thanks in advance
I use them and shorted the strut tubes about 40 mm from memory ( running in my sigma )
the car is quite low and has small dia springs
but if you only need to shorten 10 mm why not just machine the tops of your inserts
its easy enough the crome bar is not a hard material to machine
- karl_2ltgc
8610-1263SPORT
Koni part number for camira inserts....
- Rally_2.6LC
a few of the guys who rally lancers do this because you can get Billstein's for commodore's (VN I think) and yea just need a small spacer......wouldnt go 20c pieces ide get someone to make up a propper spacer on a lathe for it.davetrees wrote:Commodore inserts drop into GH tubes, apparently ..... just need a small spacer (eg. a couple of 20c pieces) underneath.
'75 GC daily (slowly dying)
^This side up^
Formely "Matt"
^This side up^
Formely "Matt"
VB-VP Commodores use the same struts, the shocks go straight in. Got two sets of GH struts, one with Commo bilstein's and the other with Audi Koni's which are shorter and required the strut be cut down by about 40mm from memory.
Why ? A spacer is a spacer is a spacer .....Rally_2.6LC wrote:wouldnt go 20c pieces ide get someone to make up a propper spacer on a lathe for it.
.... and 20c pieces are probably cheaper than thick washers !
Okay, so my GH struts have been made into coil overs. I think they are stock height. If I use stock VB-VP inserts how will they sit in the GC???
Will it be heigher than normal, the same or lower???
I understand the height is adjustable by winding the spring up and down, also spring height matters but i want to know difference between stock GC strut and a GH strut with VB-P insert???
If you are talking ride height I dont think it will make any difference at all - that will depend on the springs you choose.
John Ruskin
John Ruskin
- Rally_2.6LC
It will depend on the springs, however u will notice that u feel bumps a lot more because the shocks are designed for a Commodore that weighs almost twice what our little Galants weigh......but it also means u can hit speed bumps faster and next to nothing happens, so if u ever need to race a fully lowered Skyline or WRX make sure u pick a bumpy route or one with speed bumps lol.
Cheers Matt
Cheers Matt
^This side up^
Formely "Matt"
^This side up^
Formely "Matt"
LOL, that's good advise Matt, cheers.
Just a heads up for those looking to use Commonwhore inserts, if you are not buying new make sure you get the screw in caps too. Mine were new so they came with them but I noticed the GH insert is a smaller diameter and the stock locking/screw in nut wont fit. Everything else fits perfectly, now I just need some 60mm springs. I shouldn't need to go lower than stock on the spring height as I have about 3 inches I can wind it down anyway.
PS I bought the monroes off ebay linked above.
