which 70's/80's mitsus came with 2pc driveshafts?
A57C
Post by A57C »
and used a carrier (or prop shaft) bearing like this?
Benharjon
Re: which 70's/80's mitsus came with 2pc driveshafts?
Post by Benharjon »
I know the l200 came with the 2 piece tailshaft but not 100% sure about the carrier bearing...
Cheers Ben
tubby
Post by tubby »
my gh scorpy came with a two peice with a center bearing. but I couldnt get a replacement for love or money so it got retired for a one peice. the later scrorps did too. why do you need to know?
the one out of my GH looked the same but the mounts came out straight not bent.
A57C
Post by A57C »
@tubby, same reason as you! can't neither find a bearing or even a part #
the vr4 uses that bearing in the pic, but it costs $100 discounted, so same cost as a retube. oh well
RaptorReed
Post by RaptorReed »
You could take the HH GVR4 one and do something like this with it,
found on a Mighty Max/L200 forum.
I used a carrier bearing from a talon. Cut the housing, pryed it apart (of each) and swapped in a known good one, compressed with a C-clamp and rewelded it up.
I can give you the HH GVR4 carrier bearing PN# if you want it?
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
A57C
Post by A57C »
thx anyways tim, but i think i'm giving up
